Question about Dryers
No heat in indesit dryer. cycles as normal
No heat in indesit dryer (model IS31VS). sometimes works but then it goes cold.
  • elvistru Mar 12, 2009
    i have the same probs is it the relay my hotpoint is a condenser type WMA60 please help anyone
  • 44 Answers
Hi
remove back panel and with a mulitmeter check the stats to see if open circuit if so replace and should be back to normal.
regards
Posted on Mar 21, 2009
My whirlpool gas dryer model # LGN2000JQ2 works and heats up but after a few minutes stops blowing heat, just cold air
Most common issue are the coils on the gas valve. On front part of burner. Easy to install and not expensive. Could be cycling thermostat, but I would lean toward the coils. First thing to always check is your vent. The chute that your lint screen goes into sometimes fills up and restricts air flow. Causing unit to short cycle.
Mar 31, 2011 | Dryers
Indesit condensor tumble dryer does not heat up
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 08, 2011 | Indesit IS70C Electric Dryer
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
heatman101
Jan 05, 2011 | Indesit Dryers
Reset on indesit dryers not heating
heatman101
Nov 01, 2010 | Indesit IS70C Electric Dryer
I have an indesit IS60V tumble dryer and it's no longer drying my clothes even though the dryer tumbles fine. I have checked the filters to ensure they are clean and the vent hose which all appear ok.
heatman101
Sep 24, 2010 | Indesit IS70C Electric Dryer
My indesit is70c tumble dryer is just blowing cold air,
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Indesit Dryers
Was getting one heat cycle then ignitor woud glow but no call for gas. put in new cycling thermostat, thermostat boosting heater and heat sensor. I got two heat cycles before it went cold..?
heatman101
Aug 08, 2010 | Amana DLG330RAW Gas Dryer
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
133 people viewed this question
Top Dryers Experts
