Question about Ariston Technologies Dishwashers
Ariston LSI 48A starts on glass cycle then skips through to the second pots and plates cycle and goes for hours & hours til I open the door to stop it. It works only on either of the rinse cylces properly. How do I fix this problem?
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
huuum
  • 750 Answers
SOURCE: candy cs455m
Welcome to fixya.
I'm Huuum at your service.
You said, The dial goes through one cycle but it stops when it gets into another cycle and there seems to be no heat because when you stop the cycle and open the door the plates are cold and the water has not been dried off
I believe your timer may be bad and in need of replacement.
But before you do this, you should read the report I pasted below.
Especially because this model is an inexpensive model!
Repair or replace?
When to pull the plug on your old Appliance
The answer depends mostly on the age of your appliance,
If your appliance is under warranty or less than four years old
Note that appliances under warranty might require service from a factory-authorized technician;
If your appliance is out of warranty and is four to seven years old,
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive applaince
six or more years old .
of a appliances you replace is likely to end up in a landfill.
Please remember to leave a rating before you sign off!
Thank You, HUUUM
Posted on Sep 30, 2008
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Dishdrawer beeping constantly
leave it unpluged to stop for now, the machine has detected a leak and is constantly running hte pumps within the drawers to try to remove any water.. problrm is the water detector is in bottom under the lower drawer and htere is no pump to remove that water ..canbge a fickle machine as far as leaks are concerned, but the easy reason is usually misloading of the drawer itself, was an item put in that was too tall , preventing the lid from coming down and sealing off drawer causing water to overflow down the side??? there should be(so logn as no previous repairmen have taken it) a tech/trubleshooing guide taped to teh back wall behind the lower drawer, which is easily removed by unlocking hte hinges on either side of the front of drawer, explained in your manual
Posted on Nov 03, 2008
tattootech2
  • 72 Answers
SOURCE: Frigidaire dishwasher won't end cycle - will run
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Posted on Apr 07, 2010
SOURCE: I have a a whirlpool dishwasher ADG7440
hold down the on button for 5secs it will reset
Posted on Jan 27, 2011
Constant clicking of door lock
Suggestion: Try a little WD40 spray on the door, not on the machine. Close and open 2 or 3 times while plug is off the wall mains.
Click if helped.
Apr 14, 2013 | Ariston Technologies Ariston AWD12 Front...
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Ariston LI 45 door will not remain closed and will
Strip the door and re-set the switch. Ensure the metal part of the catch on the machines main body is not distorted
Jan 31, 2010 | Ariston Technologies Dishwashers
My dishwasher doesnt start
1) Ensure the dishwasher is turned off. 2) (may not apply) Turn the plastic blue lever located under the sink to the vertical position (this opens the valve, so water can go into the dishwasher) 3) Pour powder indo the dishwasher 4) Turn the dishwasher controller to the top position (the 12 o?clock position) ? this is the eco-setting. 5) Press the on/power button on the dishwasher, so that it now turned on (a light will display) 6) Move the dishwasher controller to the ?R? position (it?s on the very left), and leave it there a second or two. 7) Move the dishwasher controller back to the eco-setting (the 12 o?clock position
Apr 22, 2009 | Ariston Technologies LL64WNA Built-in...
Ariston Elixia LI68 Duo dishwasher will not start
Same problem , i fixed by opening the door compleet then cleaning the bottom of the door with a kitchen cleaning paper that may do it afther that disconect the power compleet whait 1 minut connect it al again and it should work , don't ask me why this cleaning action i just found it out
Feb 05, 2009 | Ariston Technologies Dishwashers
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Dishwashers Logo
64 people viewed this question
Top Ariston Technologies Dishwashers Experts
Renee Knafel-Bullock
Dado
Are you an Ariston Technologies Dishwasher Expert? Answer questions, earn points and help others
