Question about Garden
Have a ryobi cs26 weed eater.when its time to change string, it tightens it self up and cant get the bumper head off.why?
Change the string and put it on only hand tight.but each time it seems like it welds its self tight
  • 718 Answers
SOURCE: need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Posted on Jun 01, 2009
mrgauge
  • 17 Answers
SOURCE: Want manual for RYOBI 31 cc 700r weed eater
Try this link:
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/700r_1.html
Posted on Oct 01, 2009
Testimonial: "Thank you! Just what I needed."
bbreton
  • 437 Answers
SOURCE: want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Posted on Feb 25, 2010
SOURCE: How to restring two-string weed eater
how to restring a poulan weed eater
Posted on Jun 07, 2010
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
Ryobi electric hybrid weed eater quit working.
are there weeds stuck under the trimmer head causing it to work too hard perhaps and even short cords if not heavy enough will cause problems and burn out the motor
Jul 18, 2015 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Why won't the string advance?
many times it is because the string has welded itself inside the head . and we have to use pliers to help it get loose again .
Jun 17, 2015 | Echo New String Trimmer SRM-225 2 Stroke...
How to restring drum on Echo 210 gas trimmer
Pull the head off by turning the inner hub counter clockwise while holding the outer head still. Once the inner head pops out, turn it over and look for the string rotation arrow. If you can't find the string winding directional arrow, start the trimmer and determine shaft rotation direction (generally counter clockwise) and wind the string in the same direction as the head rotates when installed.
Pull about 5 arm lengths of string out of a string spool and cut it off. Place the inner trimmer head on an object that will hold it while you pull the string to even lengths through the winding hole (the support brackets of a pickup truck tail gate work well for holding the inner head while doing this).
Begin wrapping the string double wraps in the proper direction, laying them evenly and closely to the previous wrap, working it back and forth as the string begins to build up. Avoid crossing the string over itself more than necessary, the string can weld itself together if the strands cross to awkwardly. Once the string is wound, hold the head with one hand and slide the string through the outer head holes, avoid letting the string come unwrapped.
Carefully place the inner head down into the outer header. Avoid letting the string get caught between the inner and outer head. Once the heads are together lock the inner head onto the outer head by turning it and locking the round knobs into the outer head slots.
You can trim the string or let the trimmer guard do it. If the string doesn't feed it is either wound the wrong way, tangled between the inner/outer head or welded to itself.
Aug 19, 2014 | Echo Garden
The top tension is very tight
check that there are no pieces of cotton or other matters stuck. Turn the tension to its most loose position and by hand move a string of cotton through the tension slot. If it feels tight, remove any foreign matters and then slowly tighten it again to suit your needs..
Jan 12, 2014 | PfaFF Creative 7570
I have a 22in self propelled, how do i change the pull cord
Remove the motor shroud encasing the pull cord assy. What I do is turn the shroud over, leave the spring in it's slack position and gather up the two broken pieces of string. I lay then down in a circular motion on top of the recoil spool until the string is all coiled up, counting each loop made. That and once more is how many times you'll need to wind that spool up. When you are done winding, "round up" to make the hole in the spool meet up with the hole in the recoil housing. Once you're there, get a medium sized flat-head screwdriver and wedge it between the spool and the housing, hindering the spool from unwinding. Wedge it good. Melt the end of the new pull cord and begin outside the housing and feed the string thru the eyelet on the recoil housing. Keep feeding it ( recoil housing still upside down ) thru until you visibly see it pass thru the eyelet and into the hole of the spool. You may need to use a small pick to grab it and pull it home. Once it's out, it's not over. Pull enough string thru to tie a double-loop knot. When you're satisfied with the strength of the knot, reach down and grab the string, holding it tightly. Next reach in and pull the screwdriver loose. Nothing should move-you're holding the string. Hold the shroud with one hand and let the string slowly pay into the recoil spool. Bolt the shroud back on and go!
Sep 23, 2013 | Poulan Pro " Pro" Self Propelled Mower
Change head on trimmer
you buy spool of line and thread your self, you maybe able to buy the spool already has string on the spool, most are basic, the spool should have the direction you need to string it.unplug the trimmer, turn up side down, it have nut on it, unscrew it counter clock wise, than pull spool off restring the line for the weed eater, the string must be wound counter clock wise from the direction the weed eater or trimmer spins.
www.ask.com/mfg.name/make/model/change/head/trimmer/
Mar 21, 2013 | Troy-Bilt 25 CC Gas String Trimmer TB22EC
What is the proper way to change a string on a guitar so it doesn't slip?
The first thing to remember is that the strings will stretch so i always over tune it about a turn for small strings and 3 for the big strings. To prevent it from slipping when you are tightening the string pull it tight while turning it and make sure the string has overlapped its self a couple times before releasing it.
Apr 08, 2012 | Fender Music
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
