Question about Hitachi C10RA3 Electric Table Saws
10" Hitachi table saw blade won't go up or down or change bevel
Saw is 5 years old, went to use it after 6 months, had no problems previously. Model number I have is C10RA-no 3 at end-checked at Hitachi website.
  • 2 more comments
  • sfbrod Mar 13, 2009
    Thanks for the response Rowdy. I noticed this problem after not using the tool for maybe 6 months. Would you call WD-40 a penetrating oil?
    Or should I look for something else?
    Thanks,
    sfbrod
  • efs_perpends
    efs_perpends May 11, 2010
    Please be a little more specific. what is the nature of your problem?
  • David Ford
    David Ford May 11, 2010
    Yes it is also a water displacement and lubricant. I use it all the time on the table saws that I deal with and sometimes after using it I use a spray type dry lubricant, but you don't have to. Let me know how it goes.
  • David Ford
    Do I understand that you can't raise the blade or tilt the head. If so what I would do it use a good penetrating oil on the threads and assembly and try working the unit up and down a little at a time and spray some on the mechanism that tilts the head. Let me know if this is incorrect and I will look at a breakdown and come up with something else.
  • 25 Answers
SOURCE: Hitachi Table Saw Quit Working
Sounds like you've got problems with the armature commutator or one of the bearings is bad. Your best bet is to take it out and visit a local motor repair shop to asses the problem. A new motor could be the answer but at some heavy duty expense.
Posted on Nov 27, 2008
  • 80 Answers
SOURCE: How to change blade on 10" Craftsman table saw?
you need to grab the blade with something.maybe some pliers(if you are not going to refurbish blade) and loosen the nut in the center of the blade. i think it is a left hand thread(cw to loosen) because of the rotation of the blade. if the nut is on the left when looking from the front it is probably left handed. make sure it's unplugged and wear leather gloves so you don't get cut. install in reverse...
Posted on Jan 20, 2009
  • 15 Answers
SOURCE: truing craftsman table saw blade
Use a carpenter square to allign the blade both vertically and horizontally with your guide. This works very well.
Posted on Jan 28, 2009
  • 360 Answers
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 15, 2009
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
Saw blade creeps down when the motor is turned on
You must have a problem with table saw alignment. Check your manual or you visit this site.
Sep 11, 2013 | Hitachi C10FL 10" Stationary Table Saw...
Blade does not square up on c10fsh miter saw
To square up a mite saw blade, you need to eeither move the table or adjust it to be square if it is out in the mitre angle, or if it is out in the bevel angle the whole saw head needs to be adjusted, and this is done via the bevel adjustment at the back of the saw. There may be a bevel stop bolt to return the saw back to 90 degrees if moved to a different bevel angle. Usually the blade itself is not adjusted bu either the saw table or the bevel angle of the saw head itself to correct these issues.
Feb 28, 2011 | Hitachi Garden
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
The laser stopped working on Hitachi 12'dual compund mitr saw,are there batteries that can be replaced or does the unit need to go to a tech? The laser only worked for a month and the saw is only 3 months...
The laser modules in saws are usually powered by induction from the spinning saw blade. Since your saw is only three months old hopefully you either registered it with Hitachi when you bought it or you still have your receipt as this type of failure would be covered under warranty. Call Hitachi, they may send the part to you if you are comfortable with doing the repair or they will tell you where the nearest Authorized Service Center is for warranty work. Hitachi's number is: 800-706-7337 or 770-925-1774.
Jan 27, 2011 | Hitachi C12FDH 15 Amp 12Inch Dual Bevel...
I have a craftsman radial arm saw 113.23100 which has not been used for possibly 20 years. I cannot get the motor to rotate in order to make 45% angle beveled cuts. I have turned the bevel lock knob to the...
My craftsman 10-inch radial saw (model#113.199200) just stopped working. I had it in the driveway cutting some wood without any problems. It sat for a half hour and I went to use it again and it was running half speed then before I could even turn it off it just died. There was no popping sound or smoke, nothing! It will not start. Need help, please?
Jun 27, 2010 | Skil 10" Table Saw
I have just gotten my Hitachi 10'' compound mitre saw (C10FCE2) out of the box, and have disengaged the packing pin, and put on the stabilizion bar and handle. I can not seem to get the blade to tilt back...
the hndle at the front is for your mitre. there should be one at rear of tool to bevel (COMPOUND) IT SHOULD HAVE A HANDLE AS WELL possibly left hand thread !
Jan 04, 2010 | Hitachi C10FCE2 10" Compound Miter Saw
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
I have a 10" ryobi table saw and my bevel will not return to the 0 degree position. I can change the angle, but I can not get the blade to sit straight up and down. I can push it almost to zero with much...
I have a Ryobi folding table saw and I learned how to adjust the bevel through trial and error. There are two allen key machine set screws in the top of the table. One for 90 and the other for 45. I backed the 90 screw off past 90 and than set the blade exactly at 90. Now I screwed the allen screw in to touch the blade. It seemed to work for me. Mind you it will have to be checked often to insure a perfect cut. Good luck.
May 03, 2009 | Saws
Dw705 12" mitersaw
I do not know your machine but from previous experience I know that a sircular saw blade wobbles when it was over heated during use.
Oct 29, 2008 | Dewalt DW715 Heavy Duty 12" Single -...
Hitachi C10RA3 Electric Table Saws Logo
143 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
