Question about Air Tools & Compressors
I cant get my wagner w350 to spray motors runs
4 Suggested Answers
SOURCE: Need instruction manual for a ''Wagner 404 Plus'' airless spray gun
I cannot get the sprayer to prime or spray
Posted on Aug 10, 2009
jyackle5
  • 8197 Answers
SOURCE: I have 2 Wagner power painters, neither work at
I have had that happen to me you need to rebuild the diaphragm to **** up the paint.
Good luck
Posted on Sep 30, 2009
  • 3 Answers
SOURCE: Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Posted on Dec 14, 2009
My Wagner sprayer Is load and won't spray never used it before but it been sitting in box for long time
Try running it with "cleaner" first. In the case of Latex paint, use water. In the case of oil based paint, use Mineral Spirits. Make sure tip is clean (without sticking anything into it). Lastly (or "firstly") read the manual for info on initial setup.
Oct 16, 2015 | Wagner Air Tools & Compressors
Wiring diagram for wagner 905 steamer
Wagner Power Steamer 905 Manuals
www.manualslib.com > Brands > Wagner Manuals > Steam Cleaner
Wagner Power Steamer 905 Pdf User Manuals. View online or download Wagner Power Steamer 905 Owner's Manual.
Aug 29, 2015 | Wagner Spray Tech Wagner Power Steamer 905
What cain of oil a cant uuse for wagner 1250 hp
Your Wagner 1250 is a diaphragm airless sprayer, which uses hydraulic oil to push the diaphragm, so the oil must be hydraulic quality as it gets quite hot; don't use any other type. The Wagner part number for their quart size is 0088009
Jun 15, 2015 | Wagner SprayTech Wagner Airless Paint...
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Wagner 404 Plus Airless motor stops.
All airless sprayers are on-demand pumps. The two settings are prime and spray. When it is set to prime, the pump will draw liquid from the bucket below and pump it out the side tube and will never stop until you switch it back to spray. When set to spray, the pump will run until the pre-set pressure is reached, then stop. As soon as you start spraying, the pump will run until a few seconds after you stop spraying. Tip size and pressure setting will affect how long after you stop spraying the pump will run. A large tip and high pressure will cause the pump to run longer after you stop spraying.
Sep 02, 2017 | Wagner Air Tools & Compressors
Jul 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
115 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
