Question about Garden
Pull cord on weedeater wont recoil
I have a Stihl FS 55. The pull cord will not recoil. I took it apart and rewound the cord. It would pull 2 or 3 times with partial recoil each time until the cord was completely uncoiled. Several attempts taking apart and rewinding ended in the same pull by pull less cord to pull with. I don't have a manual so I can't give you any part #'s.
Thanks,
Wade Forshee 972 782 8265
  • 2 more comments
  • jrjc Apr 21, 2009
    pull cord on weed eater fl1500le will not retrack
  • Anonymous Mar 20, 2014
    how do you fit new pull cord
  • Anonymous Mar 21, 2014
    Spring has uncoiled
  • Anonymous Mar 30, 2014
    pull cord snaped
  • 181 Answers
Sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Posted on Mar 13, 2009
    Problem Solver:
  • 6 Answers
Hi wade come across this all the time m8 the spring is slipping or the pawl (little plastic part on the recoil drum) is worn open the recoil and take a look at where the spring is sitting in relation to the center shaft where the bolt goes through the rope spool either the bend in the spring slack or the spring catch in the center is not catching properly this means when the spring is under load it will slip when u try to pull the cord. you can either get a new spring or try and re bend the spring which only works if u can bend it without breaking the spring which happens more times than not. on the first pull of the recoil pull the cord till u can fell the engine giving resistance let the cord recoil and then pull this allows the shortest pull to start the engine, saving the recoil uncoiling if it is still not catching try the pawl a small white plastic part in the top of the rope spool if this wears out it can give the same problem but it should still recoil for u hope this helps
Posted on Jun 24, 2009
Need to recoil the spring on weed eater brand weed eater twist and edge for pull start
Posted on Aug 24, 2009
Sometimes when I try to pull start my Stihl Weedeater FS 36 it just free wheels and other times it will start. What could be causing this?
there is a small plastic finger in the recoil section that is broken . missing or worn out
get one from a service dealer or just about any mower shop spares
Jul 04, 2017 | Stihl Garden
How do I replace the starting pull cord
replace the starting pull cord Graeme, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
WeedEater string pull repair STRING WON RECOIL FeatherLite XT260
Fixing The Pull Cord to STIHL Weedwacker
How to Fix the Starter on Ryobi Trimmer
String Trimmer Starter Repair
Apr 01, 2016 | Garden
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Trying to recoil a spring on start rope on a FS 55
No but you have to be very careful not to let spring go. curve on spring should match up with molded curve on the housing.
Oct 02, 2013 | Garden
I replaced a coil on a stihl weedeater, fs 55 rc, and am having a problem with flooding. also I need the gap spec for the coil/mag
put a piece of paper between coil and magneto magnets, then tighten down. Just so it is not scraping or hitting when you pull it past the magnets . The flooding is because your possibly leaving the choke on to long . Only pull it a couple times, when choke is on. Then turn to half choke.
Sep 01, 2013 | Stihl Garden
One day when i went to start up my stihl weed eater it wouldnt pull so i took the plastic peice off and ther is a spring maybe or something right next to the pull cord and it was not on anything i pulled...
first off what model of trimmer is it? an fs what? second, if you are talking about the recoil spring you will need to go to a STIHL dealer and order a new one. If it came off one end then that means it broke and needs to be replaced and if it isn't broken but now uncoiled replacing it will be easier then trying to rewind it and put it back together
Jan 16, 2013 | Garden
Can't start new stihl weedeater fs 45
The Stihl FS45 has a particular way of getting started as do all the stihl products. We sell Stihl equipment in our store and service and repair them also. The normal starting procedure is to:
Be sure the switch is turned to the ON position which is the negitive sign (-). The (O) is the off position.
Press the primer bulb 3 times.
Move the choke lever to on.
Pull the starter cord three times only. If the engine fires, turn the choke to the off position and pull till it starts.
If the engine did not try to start during the first three pulls with the choke on, you must turn the choke off and pull till it starts.
Remember:Pulling more than three times with the choke switch on will flood the carburator on every stihl product thats on the market.
However, if the units still refuses to start, being its new and still under warrenty, return it to the repair shop that services Stihl products and they will repair it according to warrenty. All parts and labor should be honored at no cost to you. Please provide your receipt and serial number located on a silver tag located on the unit or the mechanic will get it off the unit when he works on it. Either way, it will most likely have to have a new carburator put on it. I hope this helps. Please comment back if this was helpful. Thanks; George
Mar 17, 2012 | Weedeater Garden
The pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Apr 27, 2010 | Garden
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
5,139 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
