1996 Ford F-150 5.4 idles very high (2200 RPM) doesn't seem to matter if is hot or cold.
I just solved this problem on my truck after fighting with it for 2 yrs. Mine is the 5.0 though, check your PVC valve and replace if it is bad. After that Take off your IAC and spray down with carb or brake cleaner and scrape all the carbon build up out of it and work the spring inside. you gotta really clean it out though! After that if it's opening and closing easily put it back together and it should work! you might have to adjust the idle a bit to get it all the way. But after doing this my truck went from a 2000 rpm idle down to about a 700! I hope this helps you!!
Usually high idle is a sign of a engine vacuum leak. I have seen the intake gaskets leak on the 5.4 engine. Spraying water on the intake gasket area carefully should change the engine rpm . A binding throttle cable could cause the rpm to stay high. Check at the throttle body for proper cable operation.
It can be issue
with IAC( idle air control valve) causing the problem.
There
are many other possibilities causing these idle issues. Engine idles rough.
There
are few help links with solutions to troubleshoot such idle issues.
I
suggest you refer the link below and follow
its troubleshooting details:------
Click
the link below:-----
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html
http://repairhelpcenter.blogspot.com/2012/01/engine-stumbles-coming-off-idle-when.html
http://schematicsdiagram.blogspot.com/2011/12/erratic-idle-on-car.html
Cold start problem and vehicle shudder around 2500 to
3500 rpms
http://repairhelpcenter.blogspot.com/2011/12/low-idle-when-cold-out-side.html
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
http://schematicsdiagram.blogspot.com/2011/12/gmc-idle-air-control-iac-valve.html
http://repairhelpcenter.blogspot.com/2011/10/1996-camry-intermittent-engine-failure.html
http://repairhelpcenter.blogspot.com/2011/10/engine-quits-at-idle.html
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
High
Idle Problem
http://repairhelpcenter.blogspot.com/2012/10/high-idle-problem.html
http://schematicsdiagram.blogspot.com/2012/01/while-stop-engine-idles-like-cylinder.html
http://technoanswers.blogspot.in/2012/02/idle-flair-is-noticed-on-car-rough-idle.html
http://technoanswers.blogspot.in/2012/02/high-rpm-in-neutral-inconsistant-high.html
http://schematicsdiagram.blogspot.in/2012/03/vehicle-stumbling-at-idle-and-shows.html
http://technoanswers.blogspot.in/2012/03/rough-idlestaling-and-erratic-shifting.html
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
There
I
Click
3500 rpms
High
Idle Problem
These
details will help.
Thanks.
It can be issue
There
are many other possibilities causing these idle issues.Engine idles rough.
There
I
Click
Bad miss at idle?
http://technoanswers.blogspot.com/2012/01/bad-miss-at-idle.html
Stumbling and stalling at
idle after engine rebuild?
1999 Ford F-150 Idles rough and quits when gas
pedal is pressed less?
Engine stumbles coming off idle when warm?
Erratic idle on car?
3500 rpms
http://repairhelpcenter.blogspot.com/2012/10/cold-start-problem-and-vehicle-shudder.html
Low idle when cold out side?
GMC Sonoma Stalls and idles low
GMC Idle Air Control (IAC)
Valve Replacing?
1996 Camry intermittent
engine failure while idle?
Engine quits at idle?
Car overheats and Air blows
hot at idle?
High
Idle Problem
While stop engine idles
like cylinder missing?
Idle flair is noticed on car? Rough idle? car
will not idle? Erratic idle speed?
High rpm in neutral? Inconsistant high RPM in
neutral?
Vehicle stumbling at idle
and shows code 54?
Rough idle, staling and Erratic shifting?
These
details will help.
Thanks.
3500 rpms
(IAC) Valve Replacing?
1996 Camry
intermittent engine failure while idle?
blows hot at idle?
High Idle Problem
While stop engine idles like cylinder
missing?
Idle flair is noticed on car? Rough idle? car will not idle?
Erratic idle speed?
High rpm in neutral? Inconsistant high RPM in neutral?
Vehicle stumbling at idle and shows code 54?
-----------While stop engine idles like cylinder
missing?
---------These details will help.Thanks.
