Question about Honeywell DLPH QUAD CHARGER,4SLT BATTERY STATION,POWER CRD/PWR SUPPLY (7850-QC-1E) Power Supply, Battery, Battery Charger
Battery for Model no. R-6600 BB - Honeywell DLPH QUAD CHARGER,4SLT BATTERY STATION,POWER CRD/PWR SUPPLY (7850-QC-1E) Power Supply, Battery, Battery Charger
I bought a blackberry storm 9530 few months ago and recently the screen started freezing frequently with in an hour or so. please help me solve my problem...............
The easiest thing to do is to take it to the manufacturer because the phone is still under warranty, but, if you want to repair it your self, follow the step below.
The issue you describe appears to be corruption of one or more system files within the BlackBerry OS. A forced update should restore your BB to working condition, but there is the risk that you may lose your data. If that is a problem, do not proceed.
If you wish to restore the BB, please continue below after verifying that you have the following:
A. Computer (Windows) B. BlackBerry Desktop Manager software (BlackBerry.com) C. Latest version of the BlackBerry OS for your make/model BB
To get the OS, simply log on to your carriers website and download the latest version of the OS for your BB. Once the file is saved to your computer, you need to install the setup files just like you would any other program. When completed, proceed to step.
1. Open BB Desktop Manager 2. Remove the battery cover, battery and micro SD card (if you have one) from your BlackBerry. 3. Connect the BB to your computer via USB cable (without the battery in place, just the phone's shell). 4. There should be a few drivers that will load automatically and the BB Desktop Manager will recognize your BB. 5. Close the BB Desktop Manager once it has been detected. 6. Go to the following path. C:\Program Files\Common Files\Research In Motion\App-loader 7. Double-click the "App-loader.exec" application 8. Once it loads, the application will detect your BB and proceed to update your BlackBerry's OS. 9. If you are prompted to backup your BB data, please do so. If not, then proceed to step #10. 10. Select wipe (or secure wipe) to completely remove the existing OS and data.
A fresh, updated version of the BlackBerry OS will be installed on your BB. The process takes about 35-90 minutes to complete. Once done, the BB will automatically reboot and if you had an existing backup or created one before wiping/installing, you can now reopen the BB Desktop Manager and restore your backup to the BB.
As a side note, the BlackBerry Storm 9xxx series has been known to have many flaws. The Storm2 fixed many issues, but still left a lot behind.
If the problem persists after the update, check to see if you still have coverage under the manufacturer's 1yr warranty or if you pay for insurance service, your BB maybe covered under service replacement.
Regards
Sep 10, 2011 | RIM BlackBerry Storm 9530 Smartphone
My blackberry storm stopped recieving and outgoing calls soon after i upgragraded my blackberry desktop manager while my phone connected to pc.even on my desktop manager it is showing disconnected. please...
The issue you describe appears to be corruption of one or more system files within the BlackBerry OS or that a file is locked in process and does not let the BB connect as it should. Below you will find 2 solutions to help resolve your issue.
D. BlackBerry USB Data Cable
A. Battery Pull
1. Remove the battery cover and battery from your BB.
2. Wait about 1 minute, then reinsert the battery.
3. Power on your BB and test it by making a phone call to test for outgoing calls.
4. If it works, proceed to step #5. If not, then skip down to solution B, step #1.
5. Ask someone to call you to test for incoming calls.
6. If it works, put the battery cover back. If not, then skip down to solution B, step #1.
B. BlackBerry OS Software Update
Note: A forced update should restore your BB to working condition, but there is the risk that you may lose your data. If that is a problem, do not proceed.
To get the OS, simply logon to your carriers website and download the latest version of the OS for your BB. Once the file is saved to your computer, you need to install the setup files just like you would any other program. When completed, proceed to step #1.
2. Remove the battery cover, battery and microSD card (if you have one) from your BlackBerry.
6. Go to the following path. C:\Program Files\Common Files\Research In Motion\AppLoader
7. Double-click the "AppLoader.exe" application
A fresh, updated version of the BlackBerry OS will be installed on your BB. The process takes about 35-90 mins to complete. Once done, the BB will automatically reboot and if you had an existing backup or created one before wiping/installing, you can now reopen the BB Desktop Manager and restore your backup to the BB.
Aug 14, 2010 | Cell Phones
None of the keys on blackberry 8900 is working
The issue you describe appears to be either a software or hardware-related problem. Below you'll find 2 solutions to help determine what type of issue it is and how to resolve it.
A. Software: corruption of one or more system files within the BlackBerry OS. A forced update should restore your BB to working condition, but there is the risk that you may lose your data. If that is a problem, do not proceed.
To get the OS, simply logon to your carriers website and download the latest version of the OS for your BB. Once the file is saved to your computer, you need to install the setup files just like you would anyother program. When completed, proceed to step #1.
1. Open BB Desktop Manager 2. Remove the battery cover, battery and microSD card (if you have one) from your BlackBerry. 3. Connect the BB to your computer via USB cable (without the battery in place, just the phone's shell). 4. There should be a few drivers that will load automatically and the BB DesktopManager will recognize your BB. 5. Close the BB Desktop Manager once it has been detected. 6. Go to the following path. C:\Program Files\Common Files\Research In Motion\AppLoader 7. Double-click the "AppLoader.exe" application 8. Once it loads, the application will detect your BB and proceed to update your BlackBerry's OS. 9. If you are prompted to backup your BB data, please do so. If not, then proceed to step #10. 10. Select wipe (or secure wipe) to completely remove the existing OS and data.
B. Hardware: The keyboard component has lost its tactile feedback and become faulty or the logic board (what stores the information and interconnect for the BB device) has become faulty and no longer responds to key presses).
In the event of a hardware malfunction, the solution would be to replace the failed component. A replacement keyboard costs $15-45 depending on make/model and can be replaced simply by removing the old keyboard and swapping it out for the new one. A logic board replacement is more expensive around $135-$200 because of the nature of the device. It is the central interconnect or "heart" of any mobile device/computer, as such, it is essentially viewed as buy a new device due to the cost incurred.
Aug 11, 2010 | Cell Phones
My blackberry storm screen isn't coming on. However when I plug the charger in a battery comes on the screen and the whole phone light up. When I take it off charge or try to turn it on a red light starts...
1. Open BB Desktop Manager 2. Remove the battery cover, battery and microSD card (if you have one) from your BlackBerry. 3. Connect the BB to your computer via USB cable (without the battery in place, just the phone's shell). 4. There should be a few drivers that will load automatically and the BB Desktop Manager will recognize your BB. 5. Close the BB Desktop Manager once it has been detected. 6. Go to the following path. C:\Program Files\Common Files\Research In Motion\AppLoader 7. Double-click the "AppLoader.exe" application 8. Once it loads, the application will detect your BB and proceed to update your BlackBerry's OS. 9. If you are prompted to backup your BB data, please do so. If not, then proceed to step #10. 10. Select wipe (or secure wipe) to completely remove the existing OS and data.
My bb8900 curve is frozen. Cannot access my phone or menu. Apears keys are not working. Did a soft and hard reset - problem still remains. Taken the batery out overnight and still the problem...
Aug 10, 2010 | RIM Cell Phones
My blackberry 9530 smartphone froze and reads "App error 523 reset
A. Computer (Windows) B. BlackBerryDesktop Managersoftware (BlackBerry.com) C. Latest version of the BlackBerry OS for your make/model BB
Oct 11, 2009 | RIM BlackBerry Storm 9530 Smartphone
Battery Icon with red line through it? Durring a back up, my Storm turned off and when I turned it back on this battery icon is all I get. I have a fully charged new battery in it now and it still shows...
This usually means the bb and battery got a little wet or has other issues. Try these solutions in order. They go from easisest to hardest. NOTE: If you have an insurance policy on the bb probably best just to take it in.
1. Remove the back cover. Remove the battery and the SIM card. Wait 30 seconds. Replace SIM, battery and back cover. Reboot. Plug in the bb and charge fully.
2. If that doesn't work, allow the bb to remain unplugged but ON for about 24 hours to drain the battery. Remove back cover and battery. Allow battery and opened bb to sit in a dry environment for 24 - 36 hours. Relace battery and cover. Reboot. Plug in the bb and charge fully.
3. If that fails retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in.
Jul 18, 2009 | RIM BlackBerry Storm 9530 Smartphone
My Blackberry curve 8320 won't turn on it just has a battery icon with a red line through it on screen. A new battery was tried and the problem still exists.
3. If that fails, retry step 2 but allow battery to FULLY drain then dry out again.
4. Take in to cell store.
Jun 08, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Screen shows battery with a red line through it
4. Take in.
Feb 16, 2009 | RIM BlackBerry 7130c Cell Phone
Blackberry 8310
3. If that fails, try another battery (a friends or one from your cellstore) to see if tat's the problem. If so, (a) retry step 2 but allow battery to FULLY drain then dry out again, (b) buy a new battery for $60 retail or (c) buy a new battery on ebay for a lot less.
4. Take in.
Aug 09, 2008 | AT&T BlackBerry Curve 8310 Cell Phone -...
Honeywell DLPH QUAD CHARGER,4SLT BATTERY STATION,POWER CRD/PWR SUPPLY (7850-QC-1E) Power Supply, Battery, Battery Charger Logo
Top Honeywell Office Equipment & Supplies Experts
 Mikey
Mikey
Lesley Cameron
Lesley Cameron
Are you a Honeywell Office Equipment and Supply Expert? Answer questions, earn points and help others
