Question about General Electric Water Heaters
LIGHTING THE PILOT ON MODEL # GG38TO6AXKOO
Model # GG38TO6AXKOO
Vaillant gas water heater - pilot light only, not lighting the main gas ring when tap is turned on..
first check to see if the thermocouple is close enough to the pilot. if it is and won't light the ring, replace the thermocouple.
Mar 01, 2014 | Water Heaters
Charmglow ventless lp gas fireplace model CGL300TQ pilot light wont stay lit, how do i know if its thermocouple or regulator?
if the therocouple has packed up pilot light will not light thermocouple has long small diameter pipe leading to a larger end this needs to be above the pilot flame also for safety have a small bowl of soapy water with a brush wet the nut with soapy water in no bubbles appear then try lighting heater thermocouples don't last that long
Jan 26, 2013 | Rheem 36" Water Heater Thermocouple Kit
I have smoth's hot water tank. problem is pilot lite is off. how do u turn it on?
You have tank-type gas water heater with standing pilot light.
Instructions for lighting pilot light are usually on front of water heater.
Since water heaters vary widely, if you want specific information without guessing, then add a comment with model number that appears on label on side of tank, and also describe the gas control valve on front of unit.
This information will let expert located manual and look up specific information plus troubleshoot steps for that model.
Aug 24, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I need to know how to lite the pilot. Can't find the maunal.
If you can find your model you should be able to get the instructions for lighting the pilot light at this Whirlpool web site
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
Sep 14, 2010 | Whirlpool Water Heaters
I have a Kenmore water heater model number 153339461. Tried to light per instructions and pilot still is not lighting. What else should I do?
If the pilot is not lighting, you may have a lot of air in the gas line. If the pilot light is not staying lit, you may have to change the thermocouple.
Sep 07, 2010 | Water Heaters
I have atwood pilot relight model gc6aa-8 pilot will light but after tank heats up & there is no call for hot water,pilot is out and very hard sometimes impossible to relight.
So are you saying that the first initial lighting of the pilot, without turning to on, works o.k., good flame etc, ? If not sure, try lighting pilot only, and leave setting at pilot only, and see if it's a good flame, and get back to me.
May 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
Water Heaters Logo
73 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
