Question about Sony VAIO PCG-K35 Notebook
No sound I've never liked the sound on my laptop but now I get none. It's ok with earphones but even that volume is low. I have checked the settings and they're all on high. Do you think I need a sound card?
The sound output is very low even using earphones can the audio output be upgraded to give a normal listening level.
Probably not without using separate amplified speakers. Check the mixer levels are set correctly.
Apr 02, 2016 | Computers & Internet
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
No sound from my laptop?
If you have no sound, there are several reasons. First, the sound may be turned off. Check the sounds icon in the control panel. Check to see if your laptop speakers are the default playback device and make sure they have not been muted. Check the little picture of a speaker in your system tray. Click on it to see if the volume is too low or the little mute square is not checked.
Rarely is the problem defective speakers--rather it's muted volume or the wrong playback mode being chosen. For instance, if you have a set of earphones and you can't hear sound from the speakers, you probably will be able to hear it through the earphones.
Apr 09, 2012 | E-Machines Computers & Internet
Sound quality is so poor. cant listen music. volume is too low even with full sound
Normally the sound on the Vostro is lower than the Inspiron series as this is an executive office laptop.
All what can be done is you can download WINAMP and use to increase the equaliser /volume still further.
Also an active power speaker can be connected to the earphone socket to improve the volume to your desired level.
Jul 13, 2011 | Dell Vostro 1014 Laptop Computer
How to connect peavey mixer to tascam 2488neo
you can get an adapter to go from the earphone jack of your MP3 platers earphone jack to any
equipment with standard line in, check Radioshack. Once you plug it in set the volume low then
adjust it up to a suitable level. Earphone jacks can overload the signal and possibly damage equipment if the volume is too high. I would avoid using phono line in it uses an even lower voltage. You can use the phono line in just be very careful about volume settings and you'll probably get some noise.
May 05, 2011 | Audio Players & Recorders
Connecting laptop to mixing deck!!
OK, try to increase the earphone socket volume by clicking on the 'speaker' icon on the task bar.
Sometimes it is not set to maximum volume in Windows' sound settings, to get full volume going to the mixing deck.
I know a DJ who used the same method to get very loud and clear sounds from his music collection at dances and parties.
Hope this helps!
Jul 11, 2010 | Dell Inspiron 1521 Notebook
Earphone volume is too low
kindly contact your network provider.may be it's related with network
Sep 22, 2009 | Cell Phones
Earphone plug is not working
do your speakers have their own volume knob? sounds like its turned way down,master volume in control panel under audio devices,also volume controll in the sound card software ,nvidia,realtek,maestro,ect. whitch ever one you have,if they are all turned up ,try turning it up useing your hotkeys on your keyboard,if none of that works,uninstall all of your audio drivers,and reinstall them from the support web site at hp.com,the wires that go to that headphone jack inside are very small,doesnt take much to damage them,droping it a couple times is enough,reinstalling the software is the best chance,if that doesnt do anything ,you will have to go inside,if this only happens when your using the optical drive then disregard everything i just said,and replace it.make sure its locked in securely
Sep 02, 2009 | HP Pavilion DV2910US Laptop
No sound from speaker can hear sound using earphone
please ensure that the earphones are unplugged when testing the speakers. also, please ensure that the mute button along the top of your keyboard is not lit-up or in the off position. (usually looks like a speaker with a strike through it).
please also check for a volume control switch or button that mey be set very low.
Jun 29, 2009 | Dell Inspiron 6000 Notebook
H10 volume
Have you tried different earphones or replacing the earphone jack?
Oct 30, 2007 | iRiver H10 MP3 Player
Sony VAIO PCG-K35 Notebook Logo
50 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
