Question about GE / Caddx Networx Programmable LCD Keypad NX148E
Battery low signal but dont know how to change the battery
I have a Users Manual for a Networx NX-148 LCD Codepad Users Manual Our alarm is beeping every minute I have identified which keypad has the low battery but dont know how o change the battery. Please help
4 Suggested Answers
  • 54 Answers
SOURCE: Contant Beeping on alarm
The Fail To Comm message is not related to your low battery problem. A Fail to Communicate occurs when the alarm system tries to send a signal (alarm, trouble or restore) to a monitoring service but can't. Most often the causes are telephone related. Has your system been disconnected from it's phone line? Have you recently changed phone services from your main carrier to an internet provider that provides VOIP service? Sometimes alarm systems have a hard time communicating over these services. Whatever the reason for the
Posted on Aug 30, 2009
ginko
  • 19396 Answers
SOURCE: I have an installed alarm
Hi.
Ensure that you have replaced batteries with alkaline type. To reset the whole system remove batteries and trip main circuit breaker for five minutes. The system gets reset when you drain power completely from all units.
Posted on Dec 29, 2010
steve_hillin
  • 44 Answers
SOURCE: Can I adjust the volume on my GE Networx NX-148E
There are a couple of things you can do, you can silence the keypad via a programming change to the alarm panel, but this requires knowing the installer or 'go' code. On the other hand, you can change the tone of the keypad by pressing * 0 and using the arrow keys to adjust the tone up and down.
Posted on Mar 05, 2011
We have a Direct Alarm Supplies home Networx NX 16 security system installed in our home after we have a power blackout & the power comes back on the alarm goes off. Is this normal or how to fix
If you have had the system for some while, its internal battery eventually looses full charge by constantly being charged by the system. When you loose power the alarm will try to resort to the battery that obviously can handle the job no longer and forces the system to alarm. Recommend that you replace the battery on a regular basis around 12 / 24 months. Otherwise may be a configuration of your system that identifies power loss as a setting.
Apr 01, 2017 | The Home Security
Two fire/smoke sectors occasionally beeping - no battery inside - connected to NetworX 1448E security system. We have changed the large battery in security - still beeping
If the units are more than 5 to 7 years old they have reached the end of life cycle and need to be replace. Smoke detector typically are only good for 5 to 10 years.
Sep 04, 2014 | Home Security
I forgot my password for my Caddx NX-8 Alarm. It was installed in 1999
My caddx nx-8 system, have started going into a instant alarm mode for no reason, what can I check for this?
Mar 30, 2011 | GE / Caddx Networx NX 8 Control Panel...
Keypad message reading 12volt low battery on three wireless zones. changed out all batteriies and still getting message.
This could be referring to your battery backup for the control panel. Make sure your battery connections are secure and check the batteries' voltage with a multimeter. If it is showing less than 12 volts and has been connected to the control panel for more than 24 hours, the battery is bad and needs replacement. Contact your local alarm company and ask them verify the battery is bad, and they can install a new one for you right then.
Feb 23, 2011 | GE / Caddx Networx NX 8 Control Panel...
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
Can I adjust the volume on my GE Networx NX-148E keypad?
Feb 10, 2011 | GE / Caddx Networx Programmable LCD Keypad...
I have a networx nx-12 (d.a.s.) home alarm and the power light is flashing. What does this mean and how do I fix it.
This indicates a low battery condition for the main control panel. Replace the battery in the main control. 12V 4-7AH usually.
Alarmprofessor.com
May 16, 2010 | Home Security
Hi Liam here I just installed a networx nx4 and when powered up key pad has 1,2,3,4 flashing rapidly with service light on I was able to get rid of service light but zones still flashing And there is only...
This could be a supervision problem. If zone expanders, gsms, keypads, etc. are added to this alarm panel, you must enroll the device with the control panel. This is done by entering into programming mode ( * + 8 + {go code} ) and then simply exiting programming mode by hitting the exit button. The GE NetworX control panel and it's affiliated compatible devices will auto-enroll after about 15 seconds. The default 'go' code is 9713, but this is usually changed by the alarm company installer.
Apr 21, 2010 | General Electric GE NX-591E-GSM NetworX...
Mar 28, 2009 | GE Interlogix Dvmre Pro 10 Channel Triplex...
GE / Caddx Networx Programmable LCD Keypad   NX148E Logo
42 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
