Question about HP DeskJet 950c InkJet Printer
How do I deep clean 950 C?
New cartridges are printing faintly, purplish.
    Genius:
  • 2,035 Answers
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Posted on Mar 12, 2009
Red ink prints as yellow, and green color is very faint. Ho wdo I clean the cartridge?
probably a problem with the cartridges ( empty)
replace with new cartridges
Dec 17, 2016 | Office Equipment & Supplies
Printer not printing very faint
Clean or deep clean the black printhead. Go to 'printer properties' then 'maintenance' and click the appropriate button.
Feb 22, 2015 | Canon Pixma MP450 All-In-One InkJet...
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
My Epson Stylus CX3900 is printing faintly though it is showing enough ink in all cartridges to print another 100 pages. Please let me know the solution. Thanks
Hey
Most epson cartridge monitors lie! unfortunately!
if the image if getting fainter try doing a head clean do this by entering your control panel and bring up the printers and devices file, click on the printers icon and look for the maintence/cleaning tab..tell it to do a deep clean if it doesn't get any better it's more than likely the cartridges are nearly out...
go and buy some new ones:-)
hope this helps,ben
Jan 04, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
Print nozzles must be blocked. Have to deep clean
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 16, 2010 | Canon i950 InkJet Photo Printer
Not printing with new ink cartridges print real faint
1) do you have original crg.?Try to performe deep cleaning of print head.
2) try to put in your old one and if its some ink in it try to print something out, if its ok buy another crg.
3) it may be purge unit error.How many print outs do you have ?
4) on Ink Cartridge you have little circle and tiny hole - blow into hole so that you get some ink drops.If then works its purge unit 100%
5) Check print head
Jan 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Canon MX700 with new cyan cartridge very faint
The print head needs a chemical solution. You have to soak it to chemical solution to unclog it. It should be a chemical solution that is really use for print head. If it does not work, the worse thing to do is to buy a new print head.
Sep 24, 2009 | Canon MX700 Office All-In-One InkJet...
Printing illegible, very faint
I run "clean printhead" and that solves the problem when it happens to me.
Mar 26, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
HP DeskJet 950c InkJet Printer Logo
222 people viewed this question
Seeker5211
Seeker5211
