Question about Water Warehouse Hayward HeatPro In-ground Heat Pump
LP (low pressure fault) is on screen.
I have a Hayward HeatPro feat pump for my pool.
The LCD screen shows LP. What does this mean and what can I do?
  • Anonymous May 23, 2009
    Did you find a solution for this? I have a hayward 21002 heapt pro with LP and it won't turn on - has power to it though. I called for service and they said $200 to come out and see and it is either the freon? or the switch?
  • mgribb May 23, 2009
    I have the same issue. A Hayward 212002 Heat Pro and it won't run. Only two years old. Is displaying an LP error on the screen - for low pressure? It is electric and is gettnig power.
    I called for service and they are charging about 180 just to come out and said it could be freon or a switch.
    Did you solve your issue? Or does anyone else have any ideas?
  • 990 Answers
Low pressure is usually a dirty filter ob basket. If you have a by-pass on the plumbing you can shut this down a little to get more flow through the heater. Or you may have a clog in your pump impeller. Hope this helps.
Posted on Oct 05, 2009
What does the LP code mean?
low pressure ,MEAN low water pressure going to the unit or low pressure refrigerant is heat pump correct ?
Jun 09, 2013 | Hayward Pool Products Hayward Heat Pro -...
Zodiac l118 heat pump lp error
low pressure if pump ok check pressure switch and line to it and wires
Mar 27, 2013 | Hayward 116k BTU HeatPro Digital Heat Pump...
I have a hayward heatpro model hp2100. the heater will run and heat the pool for a while then shuts down displaying LP on the digital screen, after a period of time it will clear the LP and have running...
LP is an error message refering to the low pressure switch. For more information about it please refer to your owner's manual here. If you decide to persue attempting to repair it yourself and need further assistance, please reply to this post with a new comment or start a new post with your specific question(s).
John
Feb 01, 2011 | Hayward Hp2100 Digital Heat Pro Heater...
What does LP stand for , Ive seen when it says PS(power save) but Trying to heat the pool and ran for a day then said LP?
John
Feb 01, 2011 | Hayward 116k HeatPro Heat Pump HP3100
Turned on my Heat Pump, kicked on for a few minutes, now it won't kick on and code said L5, now says LP. Left it alone all night, still says LP???
HOPEFULLY ITS STILL UNDER WARRANTY.
CALL HAYWARD OR GO TO HAYWARDPOOLS.COM.
THEY WILL SEND A LOCAL SERVICE REP TO COME ADJUST THE FREON LEVELS (LP).
Dec 27, 2010 | Hayward 116k HeatPro Heat Pump HP3100
My heat pump is displaying LP, what does this mean?
Low water pressure through the unit, you just need to adjust your valves to supply the right pressure to the heat pump.
Dec 29, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
This could be something as simple as a dirty filter. Heat pumps are notoris for pressure problems as they are very fickel. Make sure your filters are clean, then their should be a by-pass assembly on your inlet, outlet pipes for water this valve needs to be set at just the right spot to keep the water flow high enough to collect heat but not so high as to not warm enough. Setting this flow is easy enough with the unit on restrict the flow till the unit starts and wait to see that it keeps running. use a gentel hand and do this very slowley as the unit takes time to respond. But first make sure your filters are very clean and your baskets also. These are usually the culpret's when it comes to low pressure and low flow. The switch usually just tell's you that is where the problem is. If their is no corrosition or leaking at the pre. sw. more often than not it's ok and just tell's you to start looking for the problem. Good luck.
May 30, 2009 | Water Warehouse Hayward HeatPro In-ground...
Hayward pool heater - p5 code
The code is "PS" for Pressure Switch and means there is insufficient pressure to operate (low flow) or the switch itself is bad.
May 26, 2009 | Hayward 116k HeatPro Heat Pump HP3100
Water Warehouse Hayward HeatPro In-ground Heat Pump Logo
736 people viewed this question
Top Water Warehouse Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Water Warehouse Garden Expert? Answer questions, earn points and help others
