Question about Hampton Bay Outdoor Lighting. Ground-Stake Outdoor Copper 3-Tier Solar LED Lights 6-Pack
Solar lighjt model m24041
Post broke. on path light. Model 24041..where can we get new one? Post that is not light.
You don't understand I have no power to hazards or signals. I have broke the wire somewhere down in the wire loam I need to eliminate that wire and run a new one.
What is year--make--model?
If your talking to somebody else, if you stay on the same link, they will know your asking another question. If you make brand new post, they won't know.
To make a post on the same link, click the comment button, go from there.
W/o year--make--model, I can't look up wiring color?
Mar 12, 2016 | Cars & Trucks
I bought your Solar path lights Item #946 439 Model #SGL-1238BZ-20-4 that has a one year warrenty and have only had them a few months when one stopped working. What do I have to do to get a replacement?
It may be as simple as changing to a new battery in the defective light. If the warrenty involves any shipping cost to you, a new battery may be much cheaper. switch with a known good light.. if the light then comes on,(in the dark) problem solved.. simple circuits and l.e.d.s. not a lot can go wrong in a short time.. the battery is the weakest link. hope this helps.
Oct 26, 2013 | Dryers
SK replacement batteries for Solar Post Light with Planater
pull the unit apart and get to the batteries. Get the same size and what the content is ( ni-ca) or( ni-mh) and put them in.. You may get them from a supermarket or from a battery shop. Use the old one for a sample.
Jul 27, 2013 | Coleman Cable Post Cap Outdoor Solar...
Need a wiring schematic
Copy following link for tank-type electric water heater wiring:
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
For tankless electric:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
For tankless gas, hybrid, combo, boiler, indirect, solar, heat pump, etc then re-post question with specific brand and model number for possible help
For switches, timers, lights etc:
http://waterheatertimer.org/How-to-wire-switches.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 31, 2012 | Water Heaters
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
I have a Stanley 12 ft. Powerlock tape model # 33-212. The plastic thumb locking trigger just broke. Can I purchase a new one and if so where?
No. You'll have to replace the tape measure, or find another similar model to rob the part from...See here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 21, 2009 | Stanley Tools/Goldblatt Tool No.30 - 506...
We have an emerson vcr model ewv 401a. It is new only used twice in the past yera or so. Put in tape, tape was stuck we were able to remove the tape but the vcr keeps turning self off after about10 seconds...
there is an acrylic post inside that directs a light beam to several different places so when the light beam is broken then it tells other parts that the tape is loaded this could be broken off or if the tape broke off inside a piece could be wrapped around a capstan or drive post causing the machine to think it is at the end of the tape and to turn itself off.
Dec 15, 2008 | Stanley 100 ft. Tape Measure, FatMax
Front screen broke
Need the model number to help you, please reply to this same post with your model number.
Jun 26, 2008 | Televison & Video
Hampton Bay Outdoor Lighting. Ground-Stake Outdoor Copper 3-Tier Solar LED Lights 6-Pack Logo
246 people viewed this question
Top Hampton Bay Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Hampton Bay Garden Expert? Answer questions, earn points and help others
