Question about Sewing Machines
How to thread sewing machine
Lost the manual and can't remember correct way to thread machine, janome model 352. it's old purchased in 1990
  • Anonymous Mar 14, 2014
    Need instructions how to thread machine
  • 323 Answers
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
Top thread looping underneath fabric
I have just bought a sewing machine Jarome 352, but no manual. Where do I download its manual version? Please help me!
Oct 26, 2013 | Janome Memory Craft 9500 Computerized...
How can I get a user manual for Janome sewing machine model 352
check with janome website first about a manual
sewingpartsonline.com
sewingmanuals.com
sewusa.com
May 06, 2012 | Janome Sewing Machines
A friend asked me to thread her Janome 352 sewing machine without instruction book. The solution posted assumes that I know what all the parts are but although I have sewed for 30+ years I couldn't...
you can go to www.sewing.about.com and check out Debbie's sewing machines 101 guide. She has images, diagrams and general threading up.
or your friend can purchase a manual from here http://ifixmachines.com/vmchk/Janome-Model-352/Janome-352-Sewing-Machine-Manual/ilvm_fly1_blue.tpl.html
tally_girl_30.jpg looking at this image I would say "raise the pressure foot, take the thread from the spool holder at rear of the machine and take to the left and through the first thread guide (cant see one but there will be) then down the right side of the metal flat thing, through the guide at the bottom, then back up the other side of the metal thing and through the take up lever (turn fly wheel until this is tat its highest point to get access) then back downwards, through the thread eye near lower edge of machine head, then down to the needle bar thread guide and through the needle.
The tension device will be in that top area where the metal piece is and the horizontal white dial on left will be tension control dial.
I hope this helps you and your friend out, 4 thumbs up if so :-)
May 31, 2011 | Sewing Machines
Were can a download a harmony 2039 sewing machine manual, i have lost mine
Hi
You can download manuals for some machines from the Janome site. (www.janome.com)
I couldn't find your model listed there, even in the retired machines section!
I did find this manual for the 3128, which looks quite similar. It should help you with the basics, threading etc. Hope this helps!
http://www.janome.com/documents/File/ManualFile/3128.pdf
Sep 20, 2010 | Janome Harmony 2039 Mechanical Sewing...
Need to know how to thread bobbin
manuals can be purchased @ janome. com. your machine should have a bobbin winder. Set empty bobbin on the bobbin winder pin. Thread spool of thread though guide(or tension wheel on the top of the machine;NOT the stitching tension.) wrap thread around bobbin to start, and push bobbin toward the flywheel. slowly press foot pedal and bobbin should begin to turn. apply more pressure to foot pedal to increase speed.When full, bobbin winder should kick back to stop.
May 29, 2010 | Janome 2049LX Mechanical Sewing Machine
Owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Jan 25, 2009 | Janome Mini Compact
Janome Travel Mate - Model 4612 - Need InstructionManual
JANOME MY STYLE 16S INSTRUCTION BOOK WANTED: I have just purchase this second hand sewing machine. Does anyone have an instruction manual to sell or copy? Will pay for expenses. Contact me first on frenchy31@optusnet.com.au. Thank you. Maureen
Sep 21, 2008 | Sewing Machines
Janome 184D - thread tension
You may need to purchase a Gathering Attachment
Part No. 200 217 101
BUT be sure it is suitable for your model first
(I am unsure which one you have)
Thread tensions are set at manufacture to all = 3 for standard work, your manual is generally helpful for many answers.
The "Janome Overlocker Sewing Guide" is a very detailed publication and has this to say about Gathering without any additional attachment.
Oct 30, 2007 | Janome MyLock 634D Mechanical Sewing...
Sewing Machines Logo
448 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
