Question about Kyocera DuraXT
How to assign ringtones from sd card to a kyocere dura xt
Hi, How do I assign custom ringtones to my contacts in Samsung Galaxy S i9003? I have my ringtones in the external SD card and my contacts in SIM card. I don't want to loose my contacts in the SIM...
First of all, your contact need to be on your phone (why would anyone use limited area of SIM card ?!?) so you can be able to set everything additional on them, including ring tones.And when you place them on your phone, the procedure is trivial, just edit one contact and you will find and option to set a ringtone, choos sound when prompted and navigate to your ringtone's folder ...
Jul 27, 2011 | Samsung Galaxy S GTI9000 Smartphone
How can I set a ringtone that I have on my SD card as a download as a contact ringtone?
If you want them off the SD card, they need to be in a specific directory. Mount your SD card, and from your computer, create the following directories (if they are not there already):
-create a folder named media
-within this folder, create a folder named audio
-within this folder, create a folder named ringtones
Copy any audio files into that ringtones directory. I know mp3 and ogg files will work.
Unmount your SD card. Reboot your phone, and when you want to assign a ringtone, any of the newly copied ones should be on your list.
Mar 09, 2010 | HTC Hero Smartphone
How can I get the music I put on my sd card to be ringtones
Well first off you need two save your ringtones to the card and then plug the sd into your computer. The sound your trying to turn into a ringtone will need to blend in, meaning you will need to make sure its the same format as the other ringtones, and place it in the same folder.
Dec 29, 2009 | Samsung Reclaim Cell Phone
Downloading a ringtone to my phone
in motorola v3 razr ringtones get downloaded in the phone memory and doesnot go to the card memory . so you need to switch the memory to the phone memory and then you will be able to see that ringtone. once you move that ringtone to the card memory and then you can assign the ringtone also .
If you want ot assign the ringtone to some particular contact then it should be in the phone memory then only it wil pick up that not from the card .
Mar 26, 2009 | Motorola Mobility RAZR V3
I have sound ringtones but can't apply as ringtones on my razr
The ring-tones that are saved to your memory card, if mp3 file, will only play within your music player. You cannot assign any ringtones on your memory card. You must either download a ringtone of your choice from Sprint.com (which costs per ringtone), use your "voice memo" to record your desired music and assign it as your ringtone, or download any ringtone of your choice from certain webhosts that other the service for free such as: myxer.com, mobiles24.com, phonezoo.com, zedge.com.
Hope this helps! Thanks.
Mar 13, 2009 | Motorola Mobility RAZR V3
Motorola v750 No ringtone folder on SD card
Alas, the V750 doesn't allow you to manually add ringtones that way. The only way I've found to add a ringtone to my V750 is to email the ringtone as an attachment to my phone, then choose to save the file as a ringtone.
Every Verizon number comes with an xxxxxxxxxx@vzwpix.com email address, which comes across as a text, video, or picture message on your phone. Just replace the x's with your phone number.
NOTE: Be aware that when you open the message, your ringtone will begin playing; you probably don't want to do this at work!
Dec 26, 2008 | Motorola Mobility V750 Cellular Phone
Caller ringtones on LG shine
you need to save your contacts to the phone not the sim card.
Oct 12, 2008 | LG Shine KE970 Cellular Phone
Assigning ringtones to a profile
Do you often change your sim card. If you change sim card it may happen.
May 22, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Tranferring ringtones from SDcard to palm treo 755p
You can use a FREE program for the palm OS called minitones, you can yahoo or google it, which will allow you to convert mp3s you have on your SD card or on the phone to a ringtone that you can assign to a contact. minitones.prc
Mar 23, 2008 | Palm Treo 755p Smartphone
Ringtones
I had the same problem... after much fiddling with it, found out that only contacts saved on SIM card could have ringtones assigned. Don't know why... but saving all contacts to SIM & then assigning ringtones worked for me.
Mar 13, 2008 | Motorola Mobility RAZR V3
Kyocera DuraXT Logo
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
