Question about Sharp Office Equipment & Supplies
H4 error on Sharp SF 7370
I am looking for an operators and a service manual for Sharp SF 7370 copier.
Present problem is H4 error code and I need to decipher what kind of trouble that indicates.
  • Sharp Expert
  • 257 Answers
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Posted on Oct 31, 2009
Low fuser temperature.....probably the heater lamp, possibly the fuse. You'll have a hard time getting either of these...and I wouldn't recommend spending any money on it anyway. I suggest it might be time to retire the old beast. Only a few hundred dollars these days to get a little Digital copier
Posted on Mar 12, 2009
How do I fix the error code H4 that blinks continually on the display pane of my copier SF-750
if fixing the fuse unit by checking the thermostat and thermos-fuse then you reset the software by entering simlations by pressing # interpret cancel interpret press 14 start button
Sep 08, 2015 | Sharp Sf 750 Copier Fuser Roller Kit...
Error for sharp SF 2540 H4
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 15, 2010 | Toshiba e-Studio65 Copier
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
How do I Clear H-04 code?
C INTERRUPT 0 INTERRUPT
14
START
Apr 06, 2009 | Sharp SF 2040 Copier
Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
Replace fuser lamp and check the condition of thermistor and rectify.
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 is showing on the machine
h4 code in sharp .that s fuser temperature very high .just reset it.press clear key,auto photo key,clear,auto photo key.copier goes dead .when it goes dead just press 14 then start key.copier will bi ready after some time.it works.by mian jee
Dec 17, 2008 | Sharp SF 2020 Copier
I need help with my SF-2030 copier
A little rusty on this machine, but try this.
This code means the copier has not warmed up in a specific amount of time.
Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
If it does not reset, you may need to have a tech look at this.
Hope that helps...
Lbcoaster
Jun 28, 2008 | Sharp SF 2020 Copier
SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Mar 17, 2008 | Sharp AR C250A Color Copier
470 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
