Question about Thule Honda CRV Specialty Rack
Found radio code for 1999 honda cr v in glove compartment
Radio code
This can be found on a little sticker in your glove compartment on the top of the "door" when it is open. Alternatively, you can try getting it https://radio-navicode.honda.com/
Sep 19, 2013 | 2004 Honda CR-V
Code radio honda crv lx 2003
Inside the glove compartment, on the back side of the glove compartment door you should find a small sticker with two sets of numbers. The number set with 5 digits is you radio reset code. Turn on the radio and when the message "CODE" comes up, use the station preset buttons to input the code. If the code was input correctly, the radio should come on immediately. God Bless and ggod luck.
Sep 01, 2010 | 2003 Honda CR-V
Bought a preowned honda crv 2004 model that got involved in an accident. Delivered to me without battery. I cannot use the radio. What do I do to decode radio. Captain Victor. Ghana
Inside the glove compartment, on the back side of the glove compartment door you should find a small sticker with two sets of numbers. The number set with 5 digits is you radio rest code. Turn on the radio and when the message "CODE" comes up, use the station preset buttons to input the code. If the code was input correctly, the radio should come on immediately.
Aug 27, 2010 | 2004 Honda CR-V
Need radio code for 02 honda crv, serial #13028929
The reset code for the factory installed radio is on a sticker in the glove box. The sticker has 2 set of numbers. The number set with 5 digits is the reset code for your factory installed radio.
Jul 09, 2010 | 2002 Honda CR-V
Don''t have code to reset radio after my battery was taken out
you can call the dealer i think they can give you the code alot of times if you discanect the battery you will need to get the code i have ran into that prob being that i rebuild alternators and starters i have to discanect the battery customer had to call dealer
Apr 06, 2009 | 2002 Honda CR-V
1999 Honda Odyssey Radio Code
look for the sticker on the inside of your glove compartment its the 6 digit number.
Dec 09, 2008 | 2007 Honda CR-V
Error 7 on 2005 Honda CRV Radio
I had the same issue with the radio code error lock on a 2005 CRV. I was unaware of the code procedure and had locked the radio in the "ERROR E" mode. I was able to unlock the radio by pulling the #9 back up fuse located in the fuse box in the engine compartment. This reset the radio to CODE which then allowed me to input the 5 digit number which I had in my glove box along with my owner's manual. I am happy to report I now have a working radio/ CD player.
Nov 08, 2008 | 2005 Honda CR-V
I had to get a new battery for my car but now I need to put in the radio code but I can't find my owner's manual. Is there anything I can do?
If you have a separate audio manual It must carry the raidio code. It is must to dealer to write the radio code in the manual....
Sep 29, 2008 | 1999 Honda CR-V
Thule Honda CRV Specialty Rack Logo
65 people viewed this question
Top Thule Winter Sports Experts
ray gallant
tau1618
George Scott
George Scott
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
