Question about Sewing Machines
Brother model 1241
I picked up a used Brother 1241. It sews well, but the dial to move the stitch selection has fallen off, so I am only able to use the straight stitch. I am unable to use the Zig Zag stitch. I have the front piece dial and the spring that goes behind it but do not know how to re attach it. Can you tell me if I am able to do this myself. Are there any extra parts that I would need? Thanks for your time in advance.
4 Suggested Answers
bilabon
  • 46 Answers
SOURCE: zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Posted on Sep 02, 2008
SOURCE: My Brother LX 3125 does not sew zig zag stitches
Mine did the same thing. The needle is probably to high. Do not insert the needle all the way to the top. Lower it a bit and it should zig zag!
Posted on Feb 13, 2010
SOURCE: Pattern selection dial
take the machine back & get another one
Posted on Aug 31, 2012
My sewing machines picks what stitch it wants to use
Turn the power off and try to move the needle bar back and forth horizontally. Does it move easily? No means the installation position needs adjusted so that it will move easily. The other areas that could be a problem is 1. pulse motor or wiring needing replaced. 2. PC Board needs to be replaced.
Oct 14, 2014 | Brother CS-8072 Computerized Sewing...
Aug 30, 2012 | Brother LS-2125 Mechanical Sewing Machine
My Brother LS-2125 does not stitch forward - only in reverse.
What stitch selection have you made, anything to do with the buttonhole? If, so make sure that you let it go through the cycle then, pick a straight stitch pattern with a longer stitch length. You can also go online to brother-usa.com and see if there are any other suggestions
Sep 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
I have a brother pacesetter 607 model. It used to work very good for years but lately its not sewing the zigzag or any other stitch other than the straight stitch. can you help please? Thanks.
Simple things first, check the needle to make sure it is perfect, if you can select all the patterns and the needle moves from side to side but does not pick up the thread then it could be a timing issue and you can email me for attachment of instructions, if the needle is not moving side to side when you select a pattern then it may well be a split camstack.
drivewithken@blueyonder.co.uk
Jul 05, 2010 | Brother 925D Serger
Stitch selection
Next to the "selection wheel" there's a large-ish "hole" with a screw at the bottom, use your screw driver to wind up the screw and you'll be able to use the 9 to 15:)
Aug 04, 2009 | Brother XL-5500 Mechanical Sewing Machine
Brother mechanical sewing machine XL-5060 - Can't select stiches
I have been provided with the solution by Brother.
If I turn the Stitch Length dial to "SS" I can select stitches from 10 onwards.
Wish they could have put that in the manual!.
Jan 18, 2009 | Sewing Machines
Can't select stitches 11-21
To select stitches 11-21 you position the stitch length dial on the "SS" setting , and the pattern selecting dial on the desired stitch number.
Mar 08, 2008 | Brother XL-5700 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
