Question about Zebra LP 2844 Thermal Printer
Eltron 2844 CTP Printer on Ubuntu
I need to get an Eltron 2844 CTP Thermal Printer working under Ubuntu.
The actual printer model is "UPS LP2844PSAT", part no: "120625-005".
Zebra (who apparently now owns Eltron) has only Windows drivers on their site, and the printer wasn't in Ubuntu's "Foomatic" driver database.
Does anyone know how to get this working, or where I can find a .pdd file?
The printer supports usb/parellel/serial.
Thanks!
  • Anonymous Apr 27, 2009
    Thanks Steve,
    The driver you recommend does work for the most part. It seems to scale down the printout though. It looses about 1/8" for every inch of height. Will that adversely affect barcode reading if the barcode shrinks some?
I got it working by selecting the Zebra manufacturer, EPL2 driver.
Posted on Apr 27, 2009
I need the driver for the Zebra/eltron 2844 ctp
You can find zebra/eltron 2844 ctp driver here on this link driverupdate us .Take a look and enjoy
May 09, 2012 | Zebra Office Equipment & Supplies
I have a Zebra 2844 CTP printer: Recently changed from 2x1 hard labels to 2.25x1.25 sticky labels, and now my printer will not print my category on the label, and I get an additional blank label printed,...
The printer may need recalibrating.
Switch off - hold down feed button and switch on when indicator flashes release button.
Printer will fedd then print a configuration label. Should now be OK
Jun 03, 2011 | Zebra Eltron TLP 2844 Thermal Label...
Installed my zebra lp2844 on a new windows 7 machine. it worked at first until i turned the computer off, now it just says device has malfunctioned. USB Device not recognized. I have uninstalled and...
If you are using an Eltron printer, and you have not installed the printer driver, follow the instructions below. You must install the driver provided below. The driver provided with your printer will not work with UPS Internet Shipping.
Installing the Eltron Thermal Printer
Make sure you have set up your thermal printer equipment, cables, and thermal labels as described in your UPS Thermal Printer documentation.
The following instructions will help you download and install the UPS Thermal Printer driver program (UPS_319_117.EXE) to your selected directory.
  1. Select the Download the UPS Thermal Printer Driver link below.
  2. When prompted by the File Download - Security Warning dialogue box to choose Run, Save, or Cancel, choose Run. When prompted by the Unknown Publisher Security Warning, "Are you sure you want to run this software?", choose Run.
  3. Select Unzip to extract the files. Once files are extracted, select OK and then select Close to close the window.
  4. Navigate to C:UPSDrivers and double-click the file setup.exe to start the Installation Utility.
  5. Select the language to install.
  6. When prompted, select the Printer Interface you will be using, then click Next.
  7. USB Connection or Other Connection and click Next. You will be prompted to choose your printer model from a list. Click Next after choosing your printer model and the driver will install.
http://www.ups.com/content/us/en/resources/ship/create/labels/technical.html
Nov 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
LOOKING FOR LABELS FOR ELTRON-ZEBRA 2844 CTP UPS THERMAL PRINTER
If you are printing UPS labels, call UPS and ask for some. They will give them to you for free!
Aug 24, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Everytime I print a label it stops short of the
This is an easy printer to fix since there is only one control button. Turn the printer off. Hold the green feed key down while turning the printer on; once the red light begins flashing, let go of the feed button. This will do three things: the printer will calibrate with the installed media, it will print a configuration label and the printer will go into dump mode. Press the feed key again. One more label will come out with with the words "Out of Dump" printed at the top. If the printer still fails to print, remove the ribbon and try the same procedure with direct thermal labels (UPS or FedEx). From there, consult the manual for more troubleshooting tips.
Jan 29, 2010 | Zebra Eltron TLP 2844 Thermal Label...
ZEBRA LP 2844 PRINTING PROBLEM IN USPS SHIPPING ASSISTANT
Are you sure that the page size is wrong, or are you just guessing because of the way that the label is printing? I would uninstall the driver - delete the printer from printers and faxes and remove the driver from Server Properties (in the file drop down in Printers and Faxes). Go to ups.zebra.com/ctp and get the latest driver - you have to have the UPS version of the driver in order to support pass-through printing. Go into your UPS Ship Asst application and make sure that the generic thermal is not checked.
Jan 15, 2010 | Zebra Eltron LP 2824 Thermal Printer
Is there a driver for eltron 2844 ctp using windows vista.
http://www.zebra.com/id/zebra/na/en/index/drivers_downloads/drivers/results.html?productType=7&printerid=58
copy and paste and download from the zebra support site the drivers for Windows Vista.
Jun 17, 2009 | Zebra LP 2844 Thermal Printer
How to configure eltron 2844 thermal printer for usps label use
We are manufacturers of jewellery labels and know the problems that you are experiencing. We can offer labels which have been produced specifically to work on these printers
For more information contact: Global Imaging Group Ltd, www.globalimaginggroup.com
Feb 23, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Our Eltron Thermal printer 2844 suddenly is "not recognized"
It was a printer associated with UPS> They tried to install new drivers but it did not work: they are coming to repair machine today
Jan 27, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Zebra LP 2844 Thermal Printer Logo
1,612 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
