Question about Snapper 3100 PSI Gas-Cold Water Pressure Washer - 20397
Snapper pressure washer keeps shutting off
Will not stay running
Snapper SPX lawn mower will not stay running
How long does it run? Could be fuel filter, dirty carb, timing/valve issue, etc.
Jul 30, 2016 | Snapper Garden
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
My honda gx160 5.5 hp will only stay running if i slowly pour gas into the carb. Carb was rebuilt motor running fine last week. Put away and now wont stay running.
here is your problem,first shut off the fuel valve right underneath there is a small settlement cup that can be removed with a 10 mm wrench,once removed reopen the valve just to see if gas is flowing if not your strainer in fuel tank is clogged and can be cleaned.if you do then shut fuel valve off and remove the fuel bowl using the same wrench inside the stem there are two parts the jet and the tube,both need to be cleaned use a small screwdriver to remove the jet the tube may be stuck so maybe a small wood screw can help you remove it
Aug 09, 2013 | Karcher 2500 PSI Pressure Washer
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Engine quits running after start
It can be probably the spark plug,change the spark plug.
Apr 02, 2010 | Honda Pressure Washer PSI 3000
2-yr old troy-bilt pressure washer with honda gcv160 engine. seems to run well, but when trigger is pulled get full pressure for less than 5 seconds before reducing to house water pressure. when left...
It sounds like an air lock. Try this: With the machine off, connect the hose to the washer and let it run for several minutes to get all of the air out of the hose, and to purge any air out of the pump. Shut off the water, and connect the high pressure hose, but not the gun. Let the water run for several minutes. stretch out the HP hose and make sure that the air is displaced. Shut off the water, connect the gun, and purge as before. Now crank it washer up. As quickly as safe to do so, open the trigger to keep water moving through the washer. It should come up on pressure very quickly. It is better during normal operation to keep water moving through the system. When I am through for a while, I shut down my washer, but leave the trigger depressed to allow the pump to stay full of water, and cool. This prevents further problems when I restart it.
Hope this was useful.
Regards --W/D--
Jul 17, 2009 | Briggs & Stratton Garden
Engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
Snapper 3100 PSI Gas-Cold Water Pressure Washer - 20397 Logo
29 people viewed this question
Top Snapper Garden Experts
ray gallant
solver2010
Thomas Perkins
Thomas Perkins
Are you a Snapper Garden Expert? Answer questions, earn points and help others
