Question about Mitsubishi VS-50607 50" Rear Projection Television
Vertical roll ...........starts when system is turned-on. Picture quality is great.........just unable to stop roll or adjust adjust vertical size
  • 1 more comment
  • saintmatt6 Mar 12, 2009
    Did as suggested with negative results. Still with same problem
  • saintmatt6 Mar 13, 2009
    Did as suggested. No difference noted.
    I'm a retired police officer/CET. Formerly repaired and installed communications equipment for DC Police and the Uniformed Division of the Secret Service. Is there a manual/schematic for this unit available anywhere other than the Library of Congress???
  • Mitsubishi Master
  • 19,396 Answers
If you are using aerial reception, and the vertical roll is not on when watching DVDs , then just use a signal booster like this one, Motorola Signal Booster 1-Port BDA-S1 ..., that will stop vertical roll.
Posted on Mar 15, 2009
  • 4,234 Answers
The rolling is caused by a distortion in the video signal somewhere in the signal path. This can be caused by a defective PIP board. These are known to have problems with surface mounted capacitors. There is a "repair kit" available for this from MATELECTONICS.COM for about $14. If you can solder surface mounted capacitors, you should be able to resolve this yourself. Try installing the repair kit onto the PIP board and update this if the problem is not resolved. Please note that ALL video signals pass through the PIP module whether or not PIP is activated.
Dan
Posted on Mar 14, 2009
  • 4,806 Answers
Hi there.
The TV may just have to be reset, you will find the reset button on the left hand side of the TV's control panel, you may have to use a paperclip to push the button.
Good luck and thanks for using FixYa!!
Posted on Mar 13, 2009
  • 10,515 Answers
Here are my two suggestions:
ONE: Do a hard reset. Maybe twice. Unplug the power cord and leave unplugged for 4 hours or overnight.
TWO: Give it the whacking test. This will tell you if you have loose connections or cold solder joints acting up.
http://www.neato.org/~page/mitsu/service.html
The above site is a procedure on entering into the service mode for Mitsubishi sets..... although yours is older, it may still have similar functionality. If not, there are other service mode sites on the internet - just do a goodle search for them.
I am sure the problem is related to convergence and/or deflection circuits, but I think a diagnosis with hands-on experts will be necessary.
If we knew what the exact problem was, you could probably fix it by yourself.... But I have not experienced this symptom before and I cannot find any reference to it in the outer world (internet).
All repairs on big screen sets are expensive. I would never recommend repairs on a set this old. If you want to fix it for the reasons you stated, go ahead, but statistically speaking you should expect other failures to follow soon thereafter - sorry to say...
Thanks.
  • 1 more comment
  • taran_2005
    taran_2005 Mar 13, 2009
    Horizontal lines means the vertical deflection system which is supposed to blank them out during retrace is not working.
    Various schemes are used to control this blanking functions in modern tvs. Years ago it was always the blanking capacitor and they were clearly labeled as such on the printed boards. However, nowdays the blanking if often a software function contained with in the workings of one of the IC chips.
    I cannot find a schematic of this unit so I cannot, therefore, give you a specific identification of the process used or the blanking components employed. However, a few Sony and Mitsubishi sets that I checked have the function integrated within the jungle chip; this is the one that processes the video signal and generates all the chroma signals within the tv prior to them being fed to the picture tube drivers.
    My suggestion is to have a tech do the job unless you want to spring for a service manual and try it yourself. The service manual will cost about $25 - unless you can buddy up with a local shop that will let you look at theirs and help identify the components on the board.
    Good Luck,
    Taran.
  • taran_2005
  • taran_2005
    taran_2005 Mar 14, 2009
    Disregard the old one...
    The correct link would be
    http://www.eserviceinfo.com/index.php?wh...
    The schematics would be the same for most of the models.
    Thanks.
    Sergeant:
  • 300 Answers
Press the volume up and down button continously for 30 seconds after turning the unit.on the tv control pannel.also if you have remote do the same on remote for 30 seconds to make it functioned by the remote.
    Sergeant:
    Champion:
  • 435 Answers
Hi, This is a vertical hold problem.
You can try connecting the Cable to directly the RF input jack on the TV.
If it doesnt work, there could be a problem with the power suppply unit which connects to the tuner section inside the TV. Probably replacing the filter capacity in it would work.
Good Luck :)
Posted on Mar 12, 2009
    Genius:
  • 1,139 Answers
This can mean that the vertical sync pulses are too low, hoever this is highly unlikely, so the other point could be that the vertical oscillator is malfunctioning.
  • 564 Answers
Unplug all the connections and leave it for 5 mins and try connecting it back
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
  • Prem  Kumar
    Prem Kumar Mar 13, 2009
    This model has vertical hold adjustments but I am not sure if they are on the front panel or the back panel or the on-screen menu.  Since the set is old, it could be anywhere.
    If you cannot find it, let me know.
    When you do find it, just adjust it when the set is first turned on until the picture locks in.
    Let me know if you need further help.
    Thanks,
    PREM
    Brigadier General:
  • 3,614 Answers
check first the connections from your tv. unplug the unit and change the elec outlet.
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Jun 10, 2013 | Televison & Video
Picture roll up and down
Standard CRT televisions have a vertical roll adjustment,usually on the back at the bottom.
It may look like a white finger-knob (about the size of a pencil eraser) with a small screwdriver slot in the end...or it may be a roll-wheel...either way, it will be labeled "vertical" (or just "vert").
Make slow adjustment to the vertical until the roll stops.
*Use a solid signal for the adjustment, like DVD, VCR or cable...a weak signal can cause a bit of roll, too.
Apr 11, 2010 | Sony Televison & Video
The picture on my TS-4573 rear projection tv has started to roll vertically at a fast rate. How can I make this stop. On old tv's there was a vertical hold adjustment on the back that you could play with...
this fault is caused by defective electrolytic capacitors in the vertical deflection circuits, they need to be changed out, do this before it causes more problems, there are no adjustments for this anymore.
Jan 30, 2010 | Televison & Video
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
Rolling picture
Dear, this is problem in the circuit, you need to change the VHold you your tv, but it is not an easy job, if you don't have knowledge about fixing it, it would be better to visit the repair shop, otherwise it will affect the picture tube quality and cause further damages.
Best regards.
May 27, 2009 | Televison & Video
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Cyberhome 402 DVD "rolls"
I think I had switched to the PAL format by mistake. Fixed the problem by buying a new DVD player, was cheaper than the factory fix.
Jul 30, 2008 | Cyberhome CH-DVD 300 DVD Player
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Mar 27, 2008 | Sony KV-32S16 32" TV
Tv roll
Are you sure the roll isnt Vertical? as if it is then all you need to do is adjust the VERTICAL HOLD PRESET POT which should be located on the PCB somewhere, its very unusual for TV.S to roll horizontally as then the picture just goes out of sync. and you would not see a picture at all. When you find the pot turn it ( with a small screw driver) slowly until the rolling stops, if it does not stop then you have a faulty component in the vert. sync. circuitry.
Feb 04, 2008 | Televison & Video
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
120 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
