Question about Samsung HP-P4261 42 in. HDTV-Ready Plasma Television
Samsung hpp4261 Ok, My plasma TV went out the other day. So I call BestBuy to have someone come look at it. They told me the y-main board is out. Is there anyway I can fix the board. I know which capacitor is bad. Think I could get a new one and solder it back in? Or should I just buy a new board. If a new board is the way to go, where would be a good place to buy one. Thanks for your time! Jason
  • Jason Wunderlich Sep 19, 2007
    Yup, I bought a new board and its working fine, so far! I still would like to know what you came up with? Thanks
SOURCE:
TVtechmaniac
  • 140 Answers
SOURCE: Broken Plasma TV
The plasma display panel can be replaced part# BN96-03290A lists for $1,460.61 at Andrews Electronics. Throw in $300+ labor to do it and you be the judge.....
Posted on Sep 16, 2007
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
  • 927 Answers
SOURCE: Samsung model LNT5271f excessive relay cycling before full power
Howdy,
Yes, it is very easy to repair. Solder iron wattage should be at least 300 w.
The PSB is the center Board (towards left) after you remove the back off the TV. Remove the shield that covers the Boards and remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Good Luck, big IRISH.
Posted on Dec 28, 2009
Testimonial: "Great fix"
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 21 Answers
SOURCE: Samsung 4061F 40" LCD TV
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem.
Posted on Feb 22, 2010
Samsung plasma TV sound but no picture
Both Vs and Va voltage should be checked. As far as audio is OK, the possibility of main digital board fault.
Sep 01, 2016 | Samsung Televison & Video
I was wondering if someone could help me find which board could be bad on a Samsung PN59D8000FFXZA plasma TV.
look on the power supply board for burned parts. The board that controls the back light may have some burned parts as well.
Jul 05, 2015 | Samsung PN59D8000FFXZA - PN59D8000 59 3D...
42'' Samsung Plasma Tv Screen went black but the sound works.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sep 23, 2017 | Televison & Video
I have a Samsung plasma hpn5039, and i was watching tv and something started burning on the back, and the image went out. Does anybody know what that may be?
Two things,
1st -- power board problem
2nd -- Y- Main Board problem
If you are familiar with TV,
Open the back panel first then check the fuse on power & Y-main
Board.
It had problem that the board's which disconnected fuse on.
Feb 24, 2009 | Samsung HPN5039 50 in. Plasma HDTV
PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at [email protected],i need one.
Oct 28, 2008 | Akai PDP-5016H 50 in. HD-Ready Plasma...
42" Sanyo HD Plasma TV (Model DP42746)
Scott,
Not at all crazy! The Samsung/Akai lines seem to have numerous problems with their Y and Z sustain boards and upper/lower Y driver boards (aka buffers). That and power supplies are generally the largest percentage of the problems in those units. That said, I'm a bit confused looking at the p/n you referenced. I don't see that as being a Samsung number belonging to a Y-sus board. Usually they start with BPxx-xxxxxx..
Lastly, while you might have every ability to replace the Y-sus board if the buffers are bad and you don't replace them you could simply burn up the sustain board when you power it up... Installing the buffers is a bit more complex than the sustain board so be really careful there...\
Good Luck
Bill
Jun 05, 2008 | Televison & Video
Plasma samsung sp-p4231
could be the Y-main board or the main board
Mar 14, 2008 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
Samsung plasma sp-r4232
Remove the power supply cable to Y Main board, check Vs on power supply board when you turn on tv.
1. If you have normal Vs, replace the Y Main board. If still not work, replace the Logic board.
2. If you don't have normal Vs when you try to turn on your tv, just replace the Power Supply board.
Jan 01, 2008 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung HP-P4261 42 in. HDTV-Ready Plasma Television Logo
95 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
