Question about Craftsman 25cc Gas Blower
Wont start gas will not get into the carb
No fuel comeing out of injectorson carb
may i know the year and type of the vehicle
Oct 26, 2014 | Cars & Trucks
Lawn mower instructions why wont it work
check for spark at plug if spark at plug then squirt some starting starting fluid in carb see if will start it should run long enough to burn out starting fluid if does check for water in gas if is drain tank and carb bowl put in fresh gas not and repeat not old gas you were using strat lawn mower if still dosnt start rebuild carb and add and additive called seafoam to the gas this is good stuff follow instrution on bottle
Sep 02, 2014 | Garden
I have a toro super cycler gts 5 model 20475 6.0 engine i put new gas in it a new spark plug but if i loosen the gas bowl no gas come out and it wont start what could be wrong
Ensure fresh gas is in tank. Follow gas line from tank to carb. Have locking pliers ready to pinch off gas line or close gas line valve. Remove gas line from carb. observe gas flow to carb. Remove carb bowl from bottom of carb. Attach gas line to carb. Does gas flow to carb. Observe float, float down gas flows, float up no gas flow. If float is bad replace float assembly or carb. Remove float mounting pin and needle metering valve. Use a bread wrapper pealed back an inch so thin wire can clean out port of meter needle. Use wire to clean out center port. Observe bowl screw look for hole thru screw, clean out with wire if preset. Re-assemble carb. Clean replace air filter. Fill oil. 30w. Prime motor, pull rope 10 times to start. No start, replace carb.
Aug 02, 2013 | Snapper 20 HP Lawn Tractor 2690578
Wont start gas
squirt some starting fluid in the carb see if it will startif not chek for spark at plug if fireing check gas for water after that remove float bowl from carb clean it out replace plug and it should start
May 18, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
My gmc jimmy truck starts with starting fluid then stopS
sounds like no gas getting to the carb. plugged fuel filter, fuel line, bad fuel pump. the carb should squirt a little gas when the throttle is pumped. leave ignition off while looking down the carb and pump the throttle linkage to visually check that gas is squirting down the carb with each stroke of the linkage. maybe you are just out of gas!!
Aug 25, 2012 | 1997 GMC Jimmy
Gas pouring out vent line on carb. engin wont start. new gas added. weve not ridden in three years.
Need to remove and clean carb, there will be a varnish residue from the old fuel that wont disolve just by adding new fuel
Feb 06, 2011 | 1998 Gas Gas EC 250
Have a honda crf100f 4cycle got spark wont start,
CLEAN THE CARB AGAIN IF IT RUNS ON STARTING FLUID ITS NOT GETTING FUEL YOU WILL NEED TO REMOVE THE JETS AND MAKE SURE THEY ARE CLEAR
Jan 23, 2010 | 2002 Honda CR 125 R
Rear wheel locked up, now wont start.
try turning the gas off and take the fuel line off and clean it out or mayb put a screw driver in though it to clean it and then take the carb apart and clean the pilot jet and the main jet then check the carb bowl for any signs of dirt and clean it out. then put the carb back together and put the gas line back on and turn on the gas. let on for about 30 seconds to a minute then take carb apart toe c if gas is in the carb or just lay the bike on its side to see if gas comes out. and if gas does come out try kicking it about 10-15 times or mayb more (no more the 25 times.)and it should start. hope this helps
Sep 07, 2009 | KTM 125 SX Motorcycles
I have a 1991 cr250 wont start it has compression ,spark and gas to carb?? feels like it wants to kick over.problem started with having gas going thru carb was flooding , completely cleaned carb now wont...
just adjust the accelerator cable that is connecting to the fuel pump.check the and repair the throttle cause its the reason why it wont start . Its flooding the because of too much release of gas to the carb.
Jul 28, 2009 | Honda CR 250 R Motorcycles
Craftsman 25cc Gas Blower Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
