Question about Samsung RS261MDPN Side By Side Freestanding Refrigerator
Reset freezer temp.
Flashing lights front temp.a little high
Freezer runs but will not freeze
Check for low freon first, You need an expert who has testers as well.
Jun 29, 2015 | Whirlpool EV250NXT Upright Freezer
The high temp light is on, liquids are now liquid,but the meat is still frozen. I live in west central mich, and the temps have been in the high 80's and low to mid 90's with relitive high humidity, about...
Not normally,Make sure you door is sealing properly also check and make sur ethe evaporator fan is running when the freezer is in a cooling mode.you may need to remove the rear panel of the freezer and check for frost build up.if there is frost build up then defrost the evaporator with a blow dryer.
then check the continuity of the heating element and make sure it is in working order.
Aug 31, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
On the bottom outside of freezer bottom front what is the on and off switch for it located between a red an orange color light
it is the fast freeze button,use it when filling up freezer when less than 1/2 full.red is a high temp warning.orange is fast freeze on/working.
Jun 18, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
The high temp light is on. What can I do to reset it? Everything seems frozen and fine in the frezzer
HIGH-TEMP ALARM SWITCH (SOME MODELS)
An audible
alarm will sound if the freezer temperature reaches
unsafe levels. The alarm operates on household electricity.If
the power
fails, the alarm will not perform.
An ON/OFF switch
allows the high temperature alarm to be
deactivated if desired. NOTE: You must open the
freezer door to
view the alarm switch. The
freezer is shipped with the switch in
the OFF position.
After the freezer has run longenough to
lower the temperature, you
may set the switch to the ON
position.
To activate the alarm, set the switch
to the ON position.
To deactivate the alarm, set the switch to the OFF position
i got this from the freezer manual from Kenmore hope this was helpful
Mar 28, 2010 | Kenmore Freezer 13.7 cu. ft. Upright...
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
Mar 05, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
The alarm light is flashing, the freezer seem to be working,
Most all cooling systems need to be in an ambient temp of about 60-65 degrees. If not, it needs a low ambient control. This helps keep the high side pressure high enough so you have the proper pressure drop accross the expansion device. This applies to coolers, freezers, a/c units, and so on. I also think, if it keeps things frozen like you want, where's the problem? You make have a control just acting stupid.
Feb 07, 2009 | Freezers
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Samsung RS261MDPN Side By Side Freestanding Refrigerator Logo
19 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
