My tv shuts off and the heat red light blink - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 75,304 Answers
What is the brand name and model number to your TV? Provide more details please. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help.
Posted on Apr 22, 2013
Slinteriors
  • 8617 Answers
SOURCE: TV shuts down with Red Light blinking
Thats an easy set to trouble shoot, but you would need the manual called toshiba power supply and shutdown circuit troubleshooter. It takes you step by step on the items to check so you can easilly pinpoint the problem. You can get that manual at the following link, they email it right after purchase and they also provide free one on one tech support so you can get help with it if you need. Heres the link
http://servicemanuals.vstore.ca/
Posted on May 10, 2008
SOURCE: tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Posted on Nov 03, 2008
ladywinn
  • 5138 Answers
SOURCE: Panasonic PT53tw53-TV shuts down, red blinking light,
Replace diodes 6301,6116,6117. on G board.Diodes will sometimes read good but break down when under load.
Posted on Jan 06, 2009
brownline45
  • 310 Answers
SOURCE: HDTV, projection tv, tv shuts off by itself, green
good day. your tv has a defect . you need a qualified technician to fix your problem. but for the best is to consult your problem to sony servive center.
Posted on Jun 24, 2010
SD Tech
  • 14553 Answers
SOURCE: wd-65737 screen comes on with mitsubishi logo then shuts off ,red light blinking
Here is a suggestion that has worked for several people:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on May 30, 2012
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
Feb 15, 2016 | Televison & Video
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Jan 06, 2009 | Sony KP-46WT520 46" Rear Projection...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Toshiba CF30E50 TV shuts off
Best first step is: Good visual inspection = look for hot spots
on PCB, check caps in those areas + solder any/all bad connections,esp. low voltage regulator pins.Look the whole
board over with magnifier = solder,solder,solder...T.
Oct 25, 2007 | Televison & Video
Cant fix my sony KP-53S65
If the TV will not turn on and the red light blinks on the front of the set, it means that the microprocessor has detected a problem in the set and shut the set down. It then blinks the red light a certain number of times, and the number of blinks is the code for why the set has shut off. How many times does the red light blink before repeating?
Aug 07, 2007 | Sony KP-53S65 53" Rear Projection...
Sony r60xbr1 tv turns on then shuts off and red stand by lite blinks 4 times
Moe,You have several Broken Conns via your Mother Board after doing about 500 in the Past 8 yrs,What you need to do is Get a Magnifying Glass and look at the Bottom of the Main Board and look for Ring Breaks around Conns *Note,Any thing on a HeatSink or Plug Conns,Will be Checked First,Use 60/40 Solder and a low heat soldering Pencil to Fix Good Luck ttech
Jul 24, 2007 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
