Question about Home
Moen single handle shower faucet, contstanly drips
I've tried to get the face plate off and it seems I'm going to break the handle it's on relly well.
    Problem Solver:
  • 6 Answers
Moen single handle - push pull has a screw beneath the handle cover plate. The Moen single lever handle has an allen wrench screw located under the curve of the handle. Once either one of these screws are removed, the handle should come off easily.
Once the handle is off, the water must be turned off and then you can remove the cartridge. Some cartridges are difficult to remove and may require a special tool. Most new cartridge packages have information on them to explain how to remove the cartridge.
Posted on Mar 13, 2009
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
Dripping
you need to get a replacement cartridge moen Faucets have a tendancy to go bad you can lok up the part number at moen .com most faucets have a warranty if not the will ship a new one in about 3-5 days
Apr 11, 2013 | Moen L82691 Adler Single-Handle Posi-Temp...
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
I have a moen 1 knob push-pull faucet for my tub/shower. When I push it in sometimes water continues to drip. It is probably 30 years old. Are their replacement parts for it?
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
May 13, 2010 | Moen & One Handle Tub & Shower Faucet
SHOWER HEAD DRIP
the problem is in the shower fitting the part with the handle ,depends on who made it but you replace washers or a cartridge some times easy some times not
Aug 11, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Single handle moen shower not turning far enough
it is your shower cartrige. ace hardware $45. hot always goes first. just check if it is a posi-temp or moan trol
Dec 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen shower faucet problem
I need to ask a few questions to solve your problem.
What Model Shower body is it?
How big is the white plastic piece?
If it is about 6 inches around (just smaller than the face plate) and you are installing this shower body in a preexisting tub/shower, this piece can be discarded. It is a guide that is used so the tile contractor knows how much room is needed to service the valve once it is installed.
If this is not the case, just post with a few details and I'll modify my response.
Nov 20, 2008 | Moen Home
Home Logo
1,008 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
