Question about Air Tools & Compressors
Model 94667 radiating fan wheel went out - Air Tools & Compressors
21 gal vertical Model 94667 will not fill tank.
Could be piston rings too. Have you looked here? http://www.centralpneumaticaircompressors.com/buying-central-pneumatic-air-compressor-parts/
Oct 14, 2013 | Air Tools & Compressors
1998 Toyota Corolla radiator heats up (gauge goes full) every time I turn on the AC Fan for 5 to 10 minutes. This is happening with or without AC on. This model has Fan seperate from AC which gets turned...
Most overheating problems are caused by a stuck closed thermostat, if it has already been replaced the next common cause is a clogged radiator, have it checked at a REAPIR SHOP OR RADIATOR SHOP IF YOU REMOVE IT YOURSELF
Apr 03, 2017 | 1998 Toyota Corolla
Started running hot when the ac was on. when i turned the ac off the temp. went down. when i got in a 25 mile speed zone the temp went back up.
If the clutch on your radiator fan is broken the fan will not spin fast enough to cool the engine. Make sure your fan shrouds are in place, otherwise the air will not be sucked through the radiator properly.
Your radiator may be clogged, the radiator cap may be broken, the thermostat may be sticking, a hose may have collapsed
http://www.popularmechanics.com/cars/how-to/maintenance/1772922
Jul 29, 2011 | 1999 GMC Safari
What does the diagnostic test code P1491 means?
Hello jhonney21,
The P1491 is Radiator fan control relay circuit code. It is set if an open or short circuit is detected in the radiator fan relay control circuit.
Regards,
netvan
Feb 25, 2011 | 2001 Chrysler Voyager
I had the coolant refilled and now the compressor fans are not working
radiator fan only working when the coolant temp over 90 degree check coolant temp on your instrument display using multifunction switch left side group on steering wheel get it hot over 90 degree and have a look is the fan working or not if not check fuse for radiator suction fan fuse chart in boot on the spare wheel with tools and fuse .
Sep 02, 2010 | 2001 Mercedes-Benz S-Class
Both of my radiator fans went out... short or what?
check your power supply to rad fan relays
Nov 08, 2009 | 2005 Chrysler 300
What type of oil for central pneumatic air compressor model number 94667
It should use 30 weight mineral oil, or 30 weight motor oil.
Aug 01, 2009 | Air Tools & Compressors
Is the radiator fan the same as the cooling fan?
The cooling fan is used to cool the radiator.
There is a sensor that turns the fan 'on' if the radiator gets too hot. A light comes 'on' to tell you the fan is 'on'.
If the fan ran all night the sensor is bad and the (sorry for the pun) the idiot light is on to tell everyone something is wrong and it needs service.
DON"T run your car with out the fan!
Jun 23, 2009 | 2005 Chrysler Town & Country
Hi I have a Central Pneumatic model 94667 air compressor that was working fine, now it will not shut off when it gets to the usual shut off pressure. thanks. George.
make sure it is actually achieving full shutoff pressure. I had the same compressor and had a valve crack and the compressor would run nonstop but never got above about 40 psi.
Apr 14, 2009 | Dewalt Heavy Duty 2 Brad Nailer Compressor...
Radiator Fans
You may have air trapped in the cooling system, this causes a hot spot and the fans run, This is a common issue on most front wheel cars, jack the front of the car up as high as you can, fill the coolant reservoir full, run the engine until hot,( don't overheat it) then shut down, let the engine cool, this should self bleed the air, refill the coolant bottle and retest for your problem, restore the wiring, the not running fan is for AC. Spray cold water from a hose on the radiator his will help get the air out after the shut down.
Oct 15, 2008 | 1998 Mazda Protege
Air Tools & Compressors Logo
50 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
