Question about Akai LCT2662 Television
Tv will not turn on
Makes tumping naise for the audio
    Champion:
  • 367 Answers
Are you still having trouble?Please let me know.Thank You very much!
Tyler
Posted on Oct 07, 2009
Grinding in front of 2004olds Alero New rotors brakes wheel bearing what could it be
Pads installed incorrectly or the backing shield got bent when brakes were installed. Raise the vehicle and spin each wheel to find the one making the naise. Now remove the wheel and spin it again and see whats making contact.
May 13, 2017 | Cars & Trucks
Squealing noise then tump when turning on heater 03 lincon navigator
Your AC compressor on the engine is the likely problem, either the pump is frozen up or the front bearing is frozen up, don't run the system or the belt will burn and fly off and strands you. Get this taken care of right away before winter. Have a local shop listen to the noise to confirm my guess as to the cause.
Sep 18, 2012 | 2003 Lincoln Navigator
I have a 1984 rx7 to get straight to the point,I park my car one evening to find out the next time i tried to start it won't. I thought it may have beenout of gas. but that was not the problem.The car...
I had a situation similar to this. My starter was not getting enough power, check your battery connections and make sure it is fully charged.
Sep 19, 2011 | 1984 Mazda RX-7
Ok i have a jl500/1v2 amp with 2 w6v2 subs and i haveing a problem dont no if the amp is two much for the subs becouse i turn the amp to get more tump and the subs pop and the yellow light filkes so i turn...
its real simple. your under powered.
your W6s RMS at 500 watts EACH and your sending em 250RMS (half what they need)
The 'pop' your hearing is the failure to supply enough power to draw the cone back in time and collides with the next wave of sound.
prove it?
drive a single W6 with your 500/1 bridged.
i'll bet your pop goes away.
long term, get another 500/1 or jump up to a 1000/1v2.
I also HIGHLY recommend JL's in-line audio cleaner. If i recall it was like 60 bucks but waaaay worth it. makes sure that theres no distortion in the source input to your amp(s), which...keeps your subs from trying to reproduce transients and delivers only clear signal to your subs void of all clipping signals. Its an active electronic compoent.
PS: if you are pushing 12W6's, i had the same setup once...I had W3s connected to my 500/1 and upgraded to the W6s...had the same issue your describing, and then got the 1000/1. happy ending.
May 03, 2011 | Jl Audio 500/1V2 Car Amp
I have a 1996 Ford Windstar my problem is the front end makes a tumping noise
Check out the Upper Suspension Turrets of the Struts, and/or, the Lower Suspension Arm anchor bushes/Lower suspension Swivel ball joints. The tightness of the nuts on the Steering Box mounting on the Cross member.
Regards,DT
Apr 26, 2011 | 1998 Ford Windstar
Put torque converter in tranny and wont turn ? is the tanny bad or is the torque converter bad.
make sure you hear two tumps or steps and you cant put your fingers betwen converter and trans case. if all of this is Ok, then your oil pump is locked or broken, you wiil need a rebuilder to fix ro replace it.
Mar 27, 2011 | 1996 Toyota Camry
T701 dryer makes a tumping sound. I turned the drum from the front panel area and the drum moves a little but I think it always has. I turn the drum with the belt and it seems to be tight. Any...
Hi Gary,
Since you are able to turn the drum with the belt, I am assuming that you have removed the cabinet of the dryer.
Look for worn bearings and support wheels for the drum. Also have a look at the idler / tension wheel as well.
The drum should not be moving around as it is sitting on the rollers. The belt should maintain enough tension to keep it from doing so. If it is able to be moved, there may not be adequate tension from the idler wheel.
Sep 18, 2010 | Asko T701 Electric Dryer
Lost of power, knocking sound
HAVE YOU CHECK YOUR OIL LEVEL? OR OVERHEATED THE ENGINE, CHECK THE ENIGINES OIL LEVEL, YOU MUST OF LOST OIL, RAN LOW ON OIL OR YOUR OIL PUMP GAVE OUT. IF THERES KNOCKING OIL NOISE, THATS NOT GOOD AT ALL. ASLO WHERES THE KNOCKING FROM TOP OT THE BOTTOM. THE TOP IS LESS TUMPING THE BOTTOM IS HARDER TUMPING AND SOUNDS HARDER WHEN ACCELARATED. LET ME KNOW. CHECK THE OILS CONDIOTION FOR GLIDERIN THE SUN YOU SEE THE RESEDUE METAL GLIDERING. IF SO THE MOTOR IS MOST LIKELY SHOT.
Aug 01, 2010 | 1998 Toyota Camry
Door opened when i came home but opened slowly then would not open again makes adelayed tumpping sound then doesn't do anything.
You need to check your door springs and the drive gear. You may have a broken spring or your drive gear may be stripped. Remove the cover from the motor unit and it will be obvious if the gear is bad.
Mar 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a 2004 honda element and when i turn in either direction it makes a tumping noise
try checking the cv joint boots they might have a leak or tear> cv joints might be giving out
Feb 03, 2010 | 2004 Honda Element
Akai LCT2662 Television Logo
76 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
