Have hotpoint ultima 1000 wm17 washing machine run wash and machine stopped. blepping and saying inlet pipe E blocked and had not taken conditioner can you help please thanks
  • 15,935 Answers
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
What does the code f-05 for a hotpoint ultima WT640 1400 SPN
F05 measn some blockage, check and clean the filter at the front; remove the top cover of the machine,(power off) and disconnect the flexible hoses from the dispenser. Check if theyre blocked. The dispenser itself can be seperated - generally held together with plastic clips. Clean out any crud or hardened detergent.
Fabric conditioner is taken from the detergent tray by siphon action. Most likely flexible siphon pipe is blocked. Remove machine top, identify the pipe coming from the softener compartment, detach and clean.
Hope helps.
Apr 15, 2011 | Washing Machines
Water coming back into Soap Powder BOx Filter Blocked Need cleaning out?
remove soap drawer this is easy it just pulls out clean this then look into the hole incase there is a lump of powder blocking the inlet pipe and clean
Jun 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a Hotpoint Ultima 1200 - WM75. At the end
Check the filter and the actual pump itself for blockage.unless you have already done so, also pump itself could be faulty.
Mar 29, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Outlet Pipe
Your machine has detected a problem with draining. The place to check is the filter located at rear of machine.To access it remove plate at bottom rear of machine & you will see a black pipe hanging vertically from the drum secured by a spring clip.The filter is in this pipe. If this is clear take off other end & check pump is not obstructed.Be aware that there will be water in these pipes so may be wise to take machine outside.Let me know if problem persists.
Nov 18, 2008 | Hotpoint Ultima WF860 Front Load Washer
Machine keeps stopping
if its right at beggining of wash could be pump blockage chack for coins or ffluff blocking filter
Nov 12, 2008 | Hotpoint Ultima WD72 Front Load...
Help
Is the presuure switch connected to the pressure pipe.. the small clear pipe that runs along the side of the drum and connectes into the swtich.. if that is okay then switch is faulty.. other problems could be that the pressure pipe is blocked try blowing into the pipe to check...
Thats the main problems hope this helps.. if not then dont hesitate to get back to me
Jan 20, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
WD440 conditioner inlet /outlet appears blocked
Hotpoint WMA36 Washing machine This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2008 | Washing Machines
Error E15 - MAchine not draining
drain is same wehatever the program. filter is likely blocked. access is not that easy. take off panel at bottom rear. filter is in pipe from bottom of tub to pump. undo this pipe, take out filter. you may have water everywhere so be carefull
Nov 10, 2006 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
