Question about Samsung SyncMaster P2770HD - LCD monitor - 27"
Samsung p2770hd wont stay on - Samsung SyncMaster P2770HD - LCD monitor - 27"
SAMSUNG REFRIGERATOR
Check to see if the condenser fan is working. Samsung has a notoriously bad condenser fan motor. This is the compartment in back. Check that forst before replacing the control board.
Mar 22, 2015 | Samsung Refrigerators
Kenmark tv manual
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
You should have its remote control to unlock the child lock. Unlock procedure to many popular brand TVs are given.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
Aug 01, 2014 | Samsung LS27EMNKU/ZM LCD TV - P2770HD 27"...
Backlight shutt off
if. it works for about 3-5 seconds and cuts off
then the power supply is the problem..
open and look for capacitors that is swollen, or change the 2x1000uf 10v/16v, change the 2x 470uf/10/16v ,or the 2 small caps by the inverter
may be swollen, you can use higher voltage caps , no problem
May 25, 2014 | Samsung SyncMaster P2770HD - LCD monitor -...
Wiring diagram
No there is not. This Model does not have any Cameras included.
Feb 22, 2013 | Samsung SyncMaster P2770HD 1080P 27-inch...
The screen turn black no image
is it hooked up to computer? if so, check your screen saver
Jan 07, 2013 | Samsung SyncMaster P2770HD 1080P 27-inch...
I HAVE A LCD TV MONITOR, MODEL P2770HD, AND I CAN NOT FIND HOW TO REMOVE STAND FROM TV. SOMEBODY PLEASE TELL ME OR SHOW ME. RON
bobhifi_23.jpgIn the area marked by the yellow line you will find four black screws.Keep the monitor on the floor & remove the screws. now keep both your toes on the base stand and pull up the monitor. If you do not want to stamp on the base ask somebody else to hold it down while you pull up the monitor. Make sure you do not apply any pressure on the front screen. Hold the edges of the monitor
Mar 28, 2011 | Samsung P2770H 27 in LCD TV
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Samsung HTDS610 Home Theater System power wont stay on!
I have the same problem.
I did my research and this is the solution:
Your HT system is overheated and the fan is not working. Just replace the fan and you will be good to go.
Ken
Aug 06, 2008 | Samsung HT-DS610 System
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Samsung SyncMaster P2770HD - LCD monitor - 27" Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
