Question about IBM MicroPortable IL1210 Multimedia Projector
How to physically unlock an IBM iL1210 projector
The above projector has a fan that needs replacing - I can see there is an unlock hole but do not know what tool to use to unlock the case without damaging it
  • 2,237 Answers
Unlock hole? where? there is usually just screws holding the top on.
Posted on Aug 19, 2009
I just need to know how to install this in an old house to replace a ceiling fixture and install a ceiling fan without having to make a huge hole in my ceiling. I can't find any instructions on the model...
If you're trying to replace a light fixture with a ceiling fan. The most important thing is to make sure that the electrical box in the ceiling can support the weight and momentum of a ceiling fan. If it's an old house, as you say, I suspect it's not. However, there are support kit, that you can but from most home centers, that will install without having to make a "huge hole" in your ceiling. If you have an attic above this room, accessing and beefing up the support of the electrical box would not be difficult. If you don't have that luxury, then the support kit is your best solution, as you don't need to have access to an attic above.
As far as the Model # 22200 is concerned ... Since you didn't mention what it was, I don't have a clue.
In any event, I hope this helps you in installing the ceiling fan. Please let me know and if you would please rate my response to you. Thank you!
Mar 25, 2011 | Heating & Cooling
I have a dell 1209s projector and the temp symbol flashes. I dont know if I need a new lamp or what? Help me? thanks
Check the lamp cooling fan of your projector. maybe its has some problem. its not running at the correct RPM. that's why the lamp get over heated and the temp lamp flashes.Do one thing, Remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector. power ON the projector and watch.
Also try to reset the lamp hour of your projector. you can see the option for reset the lamp hour in the menu. Please not one thing lamp reset is recommended only after replacing the lamp.
ok
Mar 10, 2011 | Dell 1209S DLP Projector
How to replaced the water pump.
You didn't mention the model of your car. Regardless of what model it is, if you have a mechanical fan, you need to remove it. You will need to buy or make a tool that is a flat strap of metal with holes drilled in it spaced to fit over the heads of the 10 mm bolts that hold the fan pulley on. The tool holds the fan pulley from turning while you loosen the fan. The fan unscrews with left handed threads.
The plastic shroud around the fan comes out together with the fan. On some cars, the water reservoir is attached such that it is easier to pull the whole radiator out with the shroud.
The water pump fits pretty snugly in its hole. There may be a threaded hole in the pump cover that is 'blind. That is, when you screw a bolt in the hole, it pushes against the engine block to pull the pump out of its hole.
While you are replacing the water pump, you will want to replace the thermostat as well as preventative maintenance.
That is about all I can tell you without knowing what model car you have.
Feb 21, 2011 | BMW 325 Cars & Trucks
Where can you get replacments for the lamp fan. Voltage is ok but the fan just sits and hums
hi,
do one thing. remove the fan from the projector. In the fan there will be a specification sticker. Remove the sicker. now u can see a hole in the center. its the bearing part of the fan. put one drop of oil in it. u can use any type of lubricating oil. rotate the fan leafs with finger for some time. after that re-stick the spec sticker. insert the fan in the projector.
ok
Jan 28, 2011 | InFocus X1 Multimedia Projector
Why won't my ibm thinkvision c400 wireless projector power on?
Try to check first the physical connection maybe its not plugged in properly. Use a different power cord.
Oct 22, 2009 | IBM ThinkVision C400 Multimedia Projector
Infocus LP120 projector with the shakes
if you are refering to the image shaking, you need to replace the colorwheel. if you mean the projector physically shakes, replace the fans and/or the colorwheel. they are the only 2 moving parts in the machine.
Oct 14, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
IBM projector needs a fan replaced but can't find exact model
A locked rotor indication will stop the rotation of the fan completely, however if the fan is still rotating then it wont show "locked rotor signal". If the projector is still under warranty then locate their nearest service center and get it rectified..................sodeep
Jul 31, 2009 | Computers & Internet
My projector makes a really annoying noise
It is also possible that the bearing is going bad on the fan. I'd look into getting a replacement fan if that's the case. It is probably cheaper than a replacement bulb that would be needed if the fan failed entirely.
Jul 09, 2009 | Toshiba TDP-P5 DLP Projector
I just replaced a power supply, it has one fan instead of 2. Works great but now I get an error message saying it can't find the fan (which I'm no longer using), how do I get rid of the message?
replace the fan. it needs all the fans the projector was designed with to properly cool it down. without all the fans, the lamp will overheat and cause premature lamp and projector failure. the fan has 3 wires- ground, power and sensor. if the fan spins too slow or not at all, the projector will shut down to prevent damage.
so, replace the fan.
Jun 30, 2009 | InFocus LP70+ Multimedia Projector
Wireless
Just read some product specifications with google's help. But if for wireless capabilities you mean sending/receiving images over a wireless lan, the answer is simply no. This is not a very recent model - the capability you want is present in a few recent and very expensive models (e.g. panasonic).
Aug 19, 2008 | IBM MicroPortable IL1210 Multimedia...
IBM MicroPortable IL1210 Multimedia Projector Logo
275 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
