Question about Comdial Avaya Partner ACS Phone
Change number of rings on Comdial Impact
We have a COMDIAL Impact telephone system. One of the phones rings once then goes to voicemail. How can I change the number of rings to 4-5?
Any advice would be helpful.
  • 60 Answers
Thsi change needs to be made in sys programming. Usually with a pc and vmmi software.
If you have that, call up your station and there is a setting for station fwd to vm setting you can adjust.
Dan
Posted on Aug 03, 2009
I want to change voicemail message on my comdial impact CSC phone
Log into your mailbox from your extension and then press number 3 for options follow the prompts to change your greeting, This is assuming you are using a comdial or keyvoice voicemail system since you did not state it
May 20, 2010 | Comdial Impact SCS Telephone (8324S)
Programming Ext #'s
hit the options key till you get to query then hit the intercom key or just intercom the operator and see what extension it comes up with
Jan 27, 2010 | Comdial Impact 8012S Corded Phone
How do I change display name on a Comdial Impact phone.
The Small Office lite is the voicemail system are you trying to change the name on the voicemail or the telephone set. There should be a comdial cabinet hanging on a wall if you look on the right hand side of the cabinet there should be a sticker with a american flag on it this sticker will tell you model
Jan 14, 2010 | Comdial 8024-S Impact 24-Line Phone
How to set date and time on Comdial 8024S Impact Telephone
http://dl.owneriq.net/d/d1f52d1e-de34-4f20-a842-8a329b5ad24d.pdf
Above is your manual.Date and time is on page 113 of pdf or page 103 of manual.
Hope it helps!
Jan 03, 2010 | Comdial 8024-S Impact 24-Line Phone
Comdial phone system Extension number
In a standard Impact system the entire universe of numbers is 10-41 in a standard E-80PT. You could dial 0 or 10 from the unknown extension and read the display, or just start dialing each unknown or sequentioal number until it rings.
Carl
Dec 28, 2009 | Comdial Impact 8124S Corded Phone
I don't know the voicemail password; I am trying to reset it to the default
you will need to log in from a main phone or phone with LCD screen and go to the set you need to set to default in the menu...this maybe only be done through your vendor unless you know the system password to get into the configuration mode.
May 29, 2009 | Comdial Impact 8024S Corded Phone
When I try to get my voicemail by pressing VMAIL it says no such station. Yesterday it was fine. Now our system does not pick up when someone calls. It continues to ring. We have a COMDIAL Impact...
The only way to fix it without your vendor getting envolved is to try to reboot your voicemail server/phone switch(depending on the model of your system it can be inside of your switch or separate computer).
Your voicemail is down right now
Apr 02, 2009 | Comdial 8024-S Impact 24-Line Phone
Setting up voicemail on comdial 8212S-F8
Your phone model number is no help with this problem. You could have this phone on one of several different Comdial phone systems using one of several different voice mail systems. You will need to determine which voice mail you have and locate instructions for that specific unit.
Dec 13, 2007 | Comdial Impact SCS 8212S Corded Phone
Message light won't turn off...Comdial 8212S
Try dialing (from that phone)
Intercom # 3 then that extension number(exp. 100)
Nov 27, 2007 | Comdial Impact SCS 8212S Corded Phone
We cannot hear a ring on incoming calls
Sounds like your system defaulted. Only a few phones ring at system default and you may not have those ports connected. First, you need to figure out which Comdial Impact system you have. The phone will work on a few different Comdial systems. Find the main box and get a model number from that. You'll have to tackle re-programming ringing yourself or pay a local company to do it. If you do it yourself you will need the "programming and installation" manual specific for your system. A "user guide" will be of no use to you. You can search the net for "Comdial Digitech, Impact & Impression Programming & Installation Manual" Next, I would suggest a UPS backup for your system so this does not happen again. Unless you have a large carded system with dozens of phones, your phones require less power than a typical computer so a UPS made for a computer will be fine. The system will default either when the system memory battery goes too low or I have seen a few cases where power fluctuations will cause it (like when the power goes on-off-on-off rapidly in a storm) either way a UPS system with surge protection will help.
Aug 29, 2007 | Comdial Impact 8024S-PT Corded Phone
Lands Phones Logo
730 people viewed this question
Top Comdial Lands Phones Experts
george  peters
george peters
Starnley Johnwells
Starnley Johnwells
Are you a Comdial Lands Phone Expert? Answer questions, earn points and help others
