Question about Texas Instruments TI-85 Calculator
Won't power up, flat line across screen - battery problem?
My screen just powers up to a horizontal line. Does the smaller backup battery need replacing? Is something else wrong? Thank you.
  • 35 Answers
Yes, this sounds like you'll need to replace your back-up batteries. That will probably resolve the problem.
Posted on Aug 27, 2007
SOURCE:
How do I fix horizontal thin lines across the screen?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Sep 26, 2015 | Samsung UN60EH6003F 60" LED TV 1920x1080,...
I have a 2" black line at the top of the tv. And also smaller black lines across the middle of the tv.
Dear Jeff,
It seems like the Horizontal IC in your TV is dying. This and the Vertical IC is responsible for displaying images on your TV. (Look at your TV through your Phone Camera and you will see upward scrolling lines.This is the Horizontal IC in action.)
I would strongly advise you to get your TV repaired immediately.
Oct 19, 2012 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Samsung 32" LED TV Purple Line Horizontally across top of screen
Can you please change the input device to some other you know, works? If you do not notice any problem there, look for the aerial cable going close to any power line or has interference from some other transmissions of any kind nearby.
Jul 30, 2012 | Samsung Televison & Video
Horizontal lines across whole screen
Bad inverter, or a dirty one. Remove the power cable and battery, then take apart the screen bezel, or casing. Remove the LCD by unhooking it. Disconnect the inverter. Clean it. Reconnect it. Fixed.
Feb 01, 2010 | ASUS Eee 1000H Notebook
A horizontal thin black line has appeared across screen.
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jan 27, 2010 | JVC PD-42V475 42 in. HD-Ready Plasma...
Horizontal line across screen
take it to a tech.because the diagonstic is dangerious and it won't be a simple job.could be everything & anything electronic.
Nov 29, 2008 | Olevia LT42HVi 42 in. LCD Television
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
Texas Instruments TI-85 Calculator Logo
384 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
