Question about HP Compaq Power Supply
Enable power supply from compac 270646-001
Witch connector pin's from de motherboard connector do I need to connect together to enable the power supply?
3 Suggested Answers
  • 24 Answers
SOURCE: Compaq 243891-002 desktop PC power
jump the green wire with a black one listen foe the fan to come on paperclip works good
Posted on Jan 07, 2011
SOURCE: Hi, About HP power supply part
Hello Valery, you found a solution to reduce the output voltage from HPS3KW?
The trimmer inside is very inaccessible and
I would not use the diodes do not dissipate power unnecessarily.
Thanks
Errico
Posted on Nov 06, 2011
Testimonial: "Hi Errico, I have just tested it. Perfection! I removed the old pot quite easily. I just pushed it and it dropped. The I soldered 8.2Kom pot. I was able to reduce the voltage to 44.78V."
Problem with Auxiliary 4-pin pow er connector
Can you provide any specifics on the make, model, and what the power connector is labeled on the motherboard? We'll also need the make/model of power supply and the labeling on the physical connector that your using from the power supply (i.e. PCIe, or ATX, etc.)
Sep 12, 2014 | Computers & Internet
Power supply was removed and don't no where to put wires/acer aspire
cable has 20 or 24 pin group it will only go in one way
Apr 16, 2014 | Intel Motherboard
SuperMicro H8QG6-F Continous Beep
http://www.supermicro.com/Aplus/motherboard/Opteron6000/SR56x0/H8QG6-F.cfm
Under the Link and Resources heading, in the blue banner to the right, click on - Motherboard Manual
Page 32 of the PDF file. Page 2-10 for the manuals actual page,
2-7 Connector definitions:
Power Connectors
"A 24-pin main power supply connector (JWP1), and three 8-pin CPU PWR connectors (JWP2 / JWP3 /JWP4) on the motherboard.
These power connectors meet the SSI EPS 12V (Volt) specification.
In addition to the 24-pin ATX power connector, the 12V 8-pin CPU connectors at JWP2 / JWP3 / JWP4, MUST be connected to your power supply.
Warning: To prevent damage to the power supply or motherboard, please use a power supply that contains a 24-pin and three 8-pin
power connectors.
Be sure to connect these connectors to the 24-pin (JPW1) and the three 8-pin (JPW2,JPW3 and JPW4) power connectors on the motherboard.
Failure in doing so will void the manufacturer warranty on your power supply and motherboard."
So there you have it.
YES.
These,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
NOT these,
http://www.playtool.com/pages/psuconnectors/connectors.html#pciexpress8
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 02, 2012 | Super Micro Computer SUPERMICRO H8QG6-F
Had to get a new power supply for my GT4016. When I got ready to hook up the motherboard power connector I realized the power supply has a 20 pin connector and the motherboard connector has 24 pins. Did...
on the part of the power supply there is another connection with 4 pins the 20 pin and the 4 pins click together then slot into motherboard thats usually wat the problem is theres AT and ATX motherboards see if you have those extra 4 pins hanging loose on the wires they slide into each other then into motherboard
Oct 09, 2011 | Gateway GT4016 Desktop PC
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
AOpen AX4BS motherboard front panel connections & power on.
That model motherboard does not support on/off control of the power supply. Refer to the output diagram on the power supply, and there should be pins in the connector (not used on your board) that may refer to the on/off control. Those pins should be tied together. Then the PC will turn on via the main power switch, and will require a manual turn off when the display says its ok.
Oct 24, 2009 | Acer AOpen AX4BS-V (91.89J11.001)...
Motherboard has a 24pin connector for the power supply, but the connector on the power supply has a 20 pin connect? How do I connect it correctly
i presume that is a pentium 4 or newer motherboard. you will need a power supply that has at least one or two of the small four pin connectors as well... generally if it has that the extra four pins slides onto the 20 pin connector on one side and that makes up your 24 pin connection.
Sep 10, 2009 | HP VECTRA VLI8 P3 Motherboard (KZM6120)
I would like to know how to troubleshoot a brand new Ultra LS600 power supply. I would like to go beyond hearing "it's dead" since I am getting power to the motherboard (via indicator light)m but the PSU...
You can start the PSU manually with a paper clip.
Remove the 20 pin connector from the motherboard, leave the four pin power connectors attached to your various drives (this will provide a load on the power supply when it start up (provided it is not faulty).
Look at the 20 pin connector with the connector facing you.and the locking clip to your left.
The fourth pin from the bottom LH corner should be a green colour wire and the next two wires (5th & 6th pin) should be black and next to the locking clip.
Straighten a paper clip and insert it into the 4th pin and into the 5th or 6th pin (ie connect these wires together). These wires connect to the front panel switch to turn on your computer. You are testing the power supply only and since it is not connected to the motherboard the computer won't start.
Now connect the power unit to the mains and switch on the mains, if the power supply is OK the PSU fan should spin up and your hard disk should also spin up. If nothing happens the the PSU is faulty.
You can test the +5volts and +12volts supply on a 4 pin power connector with a multimeter. The red wire is +5volts and the yellow wire is +12volts and the black wires are negative (ground). The voltage readings should be within 5% of these voltages.
There are other voltages to be checked +3volts, -5volts, & -12volts. but these are not as critical.
Dec 05, 2008 | Ultra Products Ultra LS600 Lifetime Series...
ATX Power Supply Question
Most new power supplies have a twenty pin Molex connector and a 4 pin Molex connector. If you look closely at the connectors you will see that they go together a certain way. It can be very hard to tell. Take a close look at the shapes of each terminal. Match them up exactly.
Nov 28, 2008 | Gateway Computers & Internet
Problem with motherboard MSI P35 Neo2-FR
suggest not, if you really wan try, go ahead, but i suggest not.
Jun 05, 2008 | Intel Motherboard
HP Compaq Power Supply Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
