Question about Strait-Line Straitline Laser Tape Projects Made Simple
How do I account for wall behind me when measuring room with strait-line
I am tiling my bathroom from a full strip out. The walls are plum and level all round but when I use the laserlevel, the line is out when I get back to the start corner. My builder has checked and double...
If I understand which unit this is, it's not sold as a highly accurate instrument (advertised use is for hanging pictures). No numeric specifications were given for it's accuracy. And I don't think it is adjustable. Also, by using the level on each wall progressively you might be accumulating error manually.
You can easily measure the accuracy of your laser level by taking it to a room with one long wall (the bathroom is too small) Hold the laser against the wall at the left end of the room and make a mark nearby. Have a helper make a mark on the wall at the most distant point possible (at the right end of the room) Now put the laser near the mark your helper made at the height aligned with his mark. Now, back at the left end of the room have your helper measure the vertical distance between the laser beam and your first mark. This will measure double the level's error over the length of the wall. However, this test assumes that the beam coming out of the left side and the right side are perfectly co-linear. .
Aug 06, 2010 | Garden
How to replace mirror on 2008 ford explorer
Remove front door inside handle bezel. It should snap off waway from the door. Remove the screws behind bezel. Remove the screws on the bottom of the main door trim panel. DO NOT PULL OUTWARD ON THE DOOR PANEL OR IT WILL BRAKE!! Remove the door panel by lifting the pael upward. at this point you ay have enough room to access the 3 nuts behind the mirror and te mirror electrical connector. If there is not enough room then you will have to disconect the electrical connectors and the door handle linkage on the door panel. if there is eonough room for you then disconect the mirror electrical connector first then remove the 3 nuts behind the miror. the mirror should just pull strait away from the door. Reverse this proceadure to install new mirror. This is the same for left or right side.
Jun 18, 2010 | 2008 Ford Explorer
Need explanation of what L A V U Ms Mr mean
L=Lenth
A=Area
V=Volume
U=Units
Ms=Memory Store
Mr= Memory retreive
Jun 09, 2010 | Irwin Strait - Line Sonic Laser Tape...
How do I know when i am on the stud
These usually need to be calibrated in a stud-less section of the wall so that the LED just goes out. Slide the finder over the wall slowly until the light turns on--that is the first edge. Continue moving and the LED should go out--that is the second edge. These two points should be marked lightly with a pencil and the midpoint between the marks locates the center of the stud. Note that these tools will respond to wiring in the wall the same way. Hope this helps!
May 07, 2010 | Strait-Line Strait Line 6041706 Stud...
Indoor temp is 5 degrees colder than display reads on digital thermostat
Where are you measuring the indoor temperature?
To compare it to the thermostat temperature you have to measure both temperatures at thermostat.
The thermostat will only control the temperature at the thermostat, not any where else in the room.
The room temperature depending on insulation in walls and ceiling and distance from outside wall and outside temperature, can be as high as 10° difference from outside wall to inside wall of house.
The lower the outside temperature, the greater the room difference in heating. The higher the outside temperature the greater the room difference in cooling.
Feb 13, 2010 | Honeywell Programmable Thermostat Heater
I need to find a manual for a strait-line laser level 120
I think that this is the one that you are after:
http://www.irwin.com/irwin/resources/STRAIT-LINE_X3_Instruction_Manual.pdf
If it helps, please leave feedback. If not, let me know and I'll try and help som more!
Jan 28, 2010 | Strait-Line Laser Level 120 360 Degree...
I get an error message when trying to measure Length with the Strait-line sonic laser tape.
TAKE THE BATTERS OUT AND RESET THE UNIT AND IF THAT DOES NOT WORK GO ON LINT TO THE MAKER
Jan 07, 2010 | Irwin Strait - Line Sonic Laser Tape...
Same thing for me, except diff router & cable service.
push the reset button and start from scratch
also you could be going through a metat wall or a metal faced wall they made great fariday cages in the 40's with wire mesh and plaster i cant get a signal 10 inches from my router in the next room and i mean 10 inches strait through the wall
Jul 30, 2009 | 2wire (1000-400108-001) Router
Strait-Line Straitline Laser Tape Projects Made Simple Logo
14 people viewed this question
Top Strait-Line Measuring Tools & Sensors Experts
Vuk B
Chris Delaney
Chris Delaney
Level 1 Expert
Are you a Strait-Line Measuring Tool and Sensor Expert? Answer questions, earn points and help others
