Question about Canon PIXMA MP600 all-In-One InkJet Printer
Canon mx892 won't feed paper
Says out of paper but paper is in cassette
SOURCE: "paper-feed error"
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Posted on Aug 02, 2009
SOURCE: canon ip 2600 printer. Paper does not feed
Hey I had the same problem. Called the company; we couldn't fix it. Well I turned it upside down and a 2" flower stem fell out from when I cut some flowers next to my desk. It still didn't work. I was examining the feed area while it was running and I found another little piece of stem that was lodged way in there. I had to get it out with tweasers and it turned out to be 1" long. Couldn't really see it at all. Works fine now.
Posted on Nov 10, 2009
SOURCE: Can't print business cards. Won't feed from rear tray.
I just spend over an hour on the phone with Canon for the same problem... the resolution is simple. From the Control Panel, select Printers & Faxes. Right-click the mp620 printer, and select Properties. Select Printing Preferences from the bottom of the General tab, then click the Page Setup tab. Choose Print Options at the bottom. Place a check mark in the box next to "Disable the paper source setting of the application software." Click OK 3 times and the problem should be solved.
Posted on Nov 27, 2009
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
SOURCE: canon MX850 - paper feed
Look carefully because it is a cassette on the bottom of your canon mx850... so the solution is: or you fill that cassette or you switch your canon (it is a button for that) to take the paper from the top...
Posted on Feb 15, 2010
Only prints from rear tray
You need chose paper or casette from computer. Right button on your printer/printing preferences/page setup select pages size and paper type.
May 04, 2016 | Canon PIXMA MX892 multifunction printer
How do I change paper trays on the MX892 canon MX 892 printer
Not exactly sure what you mean...but if you want to change the default tray (to print from), go to 'Printer properties' then 'Maintenance' and select which tray you want to use there.
Mar 02, 2015 | Canon PIXMA MX892 multifunction printer
Cannon error codes
Printer is in use or an error has occurred. check status. Scanner driver will be closed.
code 2,140,2
if scanner is not in use there is a problem using it with the USB unplugged.
May 15, 2013 | Canon PIXMA MX892 multifunction printer
Where might I obtain a Canon Pixma mx892 printer's manual?
http://www.manualowl.com/p/Canon/PIXMA-MX892/Manual/155533
Jan 19, 2013 | Canon PIXMA Office Equipment & Supplies
Paper feed results in a clicking and no feed
This sounds as if the paper pick up assembly is not lifting the paper-up to meet the rollers. This is like a ratcheting sound when lifting. When the paper gets high enough it hits a sensor arm and the copier will indicate paper in the cassette. If it doesn't lift it will quit but will never indicate paper in cassette. Does the other paper cassette feed? I know I've had to replace the paper pick-up assembly before because of this problem and is very expensive. Good luck.
Sep 27, 2011 | Canon imageRUNNER 210S Copier
Printer Canon LBP3300, When was printer it show "Load custom paper in manual feed slot". Have try to slot manual feed but also cant work. Please help to solve this problem. thanks
Load Legal paper in Cassette 1.
If you want to print using only one piece of paper currently loaded in the Manual Feed Slot, click [Resolve Error].
If you want to feed paper from the cassettes, remove the loaded paper from the Manual Feed Slot.
Dec 14, 2010 | Canon LASER SHOT LBP 3300 Printer
Canon MX850 - paper feed
Jul 27, 2009 | Canon PIXMA MX850 Multifunction Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
105 people viewed this question
old marine
old marine
