Question about Dell Inspiron 6000 Notebook
Dell inspiron 6000 power supply shot...
Dell inspiron 6000
my computer was dropped and now it won't accept power from the power cord. I think it's the power supply in the computer with the problem. how can i replace it or is it worth replacing? i've never opened a computer up so i would need step by step instructions...
  • earties Mar 12, 2009
    THanks alot guys.... I will definately bring it to a professional to see if its worth fixing :-)
  • Nicolas
    Nicolas May 11, 2010
    I wouldent recomend you to even try to raplace that. Take it to a pc-repaire shop and let them look at it, they will tell you the cost and then you can decide if its worth or not.
    It isent that easy to take a laptop apart, and in your case you need to separate the topshell from the bottomshell, thats not a job for someone who never done it before, belive me. Even if you manage to sepatere the shells you will have problem when you put them together again. Not worth it M8. Let the profesionals deal with it.
    Good luck
    Nic
    President:
  • 1,073 Answers
You welcome M8!
I hope it wont be to expensive to fix so you can get your laptob back alive again:)
Nic
Posted on Mar 12, 2009
    Novelist:
  • 166 Answers
There are no internal power supplies in laptops. What has most likely happened is as your laptop fell it either landed on the part of the power cord that was sticking out the back/side of the computer or the tension was so great on the plug from it falling that the power supply connector on the motherboard has broken loose from the motherboard. I have seen this happen a lot. This is not a job for an amatuer. It takes someone with knowledge of laptop repair and motherboard repair. In your best case scenarios either the little strip that contains the power button has popped loose and is not making contact (seen this happen in one case) or the power supply adapter (not part of the laptop) has been damaged and torn some wires. In the first case just try to push that power button strip down on the laptop first to see if it will snap back in place. If you can find someone else that has the same adapter you can ask to borrow theirs for a few minutes. Medium case scenario is that it has broken the solder loose and just needs to be resoldered or a new power plug soldered in. Worst case scenario is that it has cracked the motherboard, which will be expensive to fix (it would have to be replaced). Continuing to try and use it in this state (unless it is the best case scenario) will further damage the motherboard as the electricity will start jumping to places it should not go and eventually destroy the motherboard.
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
My dell computer connection seems bad. The power
i think u need a new power cord , y not taking it to a IT store
Apr 15, 2010 | Dell Inspiron 6000 Notebook
Try to turn Dell Inspiron 6000 laptop and nothing happens. No lights, no sounds, nothing. Power chord is good and has output voltage of 19.5.
remove battery and then insert power cord and power it up. if it powers, then insert battery while laptop is on. otherwise, if it doesnt, get the battery charged from else where and insert it just to confirm that the power supply unit isnt spoilt.
Regards
Feb 13, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 - faulty power cable sparked!
there is no fuse to replace. i think it completely burned. need to get service.
Sep 04, 2009 | Dell Inspiron 6000 Notebook
My power cord not charging battery
you may have damaged the power input port.
broken solder joint. or your power supply took a dive. if you have a DMM 'meter' check the power supply to see if you are getting power from it.
if it is the power input port, you will have to either open up the laptop and see if it is a fixable soldering job or take it to a pro.
Happy Fixing =)
Jul 11, 2009 | Dell Inspiron 6000 Notebook
Dell Laptop power supply charges sporadically
when i replug my Dell laptop ,the charging system does not display.
Mar 13, 2009 | Dell HQRP Replacement Laptop AC Adapter /...
Problems with the AC jack on back of Dell Inspiron 6000
there is a small metal inside the dc socket that you need to pull towards the centre so i makes better contact with the charger
Mar 02, 2009 | Dell INSPIRON 6000 CENTRINO...
Power issue
Is the new power supply a Dell. Some aftermarket power supplies, especially Targus, will not charge the battery in a Dell. If it is a Dell supply, then it's one of two things. 1- the battery is shot and needs replacing. 2- the power management chip on the motherboard is shot and the motherboard needs replacing. If the battery light is flashing orange then the battery is shot. If the battery light is green, then go into the power settings and see if the machine shows that it is charging. If it doesn't show that it's charging then it's the pm chip.
Jun 16, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
1,014 people viewed this question
Alun Cox
