Question about Xerox Phaser 8500/DN Printer
Xerox Phaser 8550 Won't Print
We're not getting an error code, but no jobs will print out. The diagnostics work fine, a test page prints, but no job sent from a network computer will print. The network is up and running fine; jobs will print on other network printers.
Any ideas?
Thanks!
  • 1 more comment
  • dante_harris Mar 12, 2009
    But the words on my command screen blink.
  • kwilliams329 Mar 12, 2009
    Check the troubleshooting display on printer screen and look under networks. My printer was doing the same thing and it showed a network link error-I don't recall the code that it listed on the display. It seems the electronic module has failed and while the printer thinks it's hooked to your network; it's actually timing out and not getting the message to print documents from the network. Cost of new electronics module to repair is $515 plus labor.
  • drews Mar 17, 2009
    @kwilliams
    The network diagnostic shows no errors.
I was having the same problem. Turns out the IP address in the printer was incorrect. Once I changed the IP address the printer works just fine through our network again. Find your IP address off your server and follow these steps:
1. Choose Info on display menu, press okay button
2. Choose Info pages, press okay
3. Configuration pages-printer info, press okay
4. IP address should read: Correct IP Address number should be displayed on screen.
If not follow these steps to change it:
1. Find printer setup on display menu, press okay
2. Go to connection setup-press okay
3. Network setup-press okay
4. TCP/IP setup-press okay
5. Auto should show as “Off”
6. TCP/IP should show as “On”
7. DHCP/Boot should show as “Off”
If any of these are not listed on display correctly press ok, reset to either On or Off and then enter correct IP address.
Press okay button and follow steps on display menu to exit back to main menu display screen.
Posted on Mar 26, 2009
Can I print using only black ink is I'm out of yellow
Posted on Mar 24, 2011
    Scholar:
  • 32 Answers
I am having the same problem now, the printer ip address is set manually to 192.168.1.100 to avoid this kinds of issues of the computers looking for the printer on another ip it previously had.
It's best to assign the printer a dedicated ip but you should probably make it a higher number than the other computers on the network so your dhcp server doesn't mistakenly assign another computer on the network the same ip address as the printer (my current issue), I don't know why my pc is being allowed to get assigned the same ip which was already manually programmed into the printer. (This is why I suggested using a higher number ip for the printer to avoid such conflicts).
It's an easy fix, reboot all the devices unfortunately for me I have a lot of open windows and processing some important info now and cannot shut down my computer now however the rest of the network is suffering now because there is an ip address conflict.
If you go to the printer control panel and go to troubleshooting and network the printer will issue a code and tell you the problem.
For me it said Duplicate IP address must be resolved for TCP/IP to function properly followed by the ip address and the mac address of the conflicting device.
Hope that helps.
Posted on Jan 22, 2011
Why does my Xerox Phaser 5500 print distorted watermarks?
Click caret ro right of friend's post, click unfollow without unfreinding.
Feb 26, 2015 | Xerox Phaser Office Equipment & Supplies
Xerox Phaser 8550 is printing green and yellow with some gray color on all the print job, even after I replaced the ink loader, the black color came back but still getting only green and yellow. The ink...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you have loads of missing jets, run a couple of head cleans, if you see improvement, it is worth running some more, if not, try switching off overnight and rebooting next day. If it still won't clear, you may have a faulty printhead.
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
Hope this helps.
Dec 25, 2010 | Xerox Phaser 8500/DN Printer
Hi, my name is Gabriel and I have the Xerox Phaser 4510, I would like to know how to print one page for both sides? Thank you
There ia a duplex unit that you could buy and attach to the machine.
Alternatively when you select "Print"
Select the option to print pages in the range "odd pages
When the job is finished place the printed documents in the manual paper feed and select "Print" again and the option to print all the even pages.
You will also have to check a box to print pages in reverse order or vice versa depending on the order the first batch were printed.
A bit of trial and error might be required before you get the correct solution. Hope this helps??
Dec 19, 2008 | Xerox - PRINTERS - PHASER 4510 (N) LASERPR...
Xerox Phaser 6100 will not print
Yeah you need to replace that imaging and transfer units for it to print. That has a counter on it and once it comes up with that message it will not print anything.
NOW THE WARANING. Once you replace the unit. Everything you have sent is in the memory and will print out.
What you will want to do is once it starts printing, continue to cancel the jobs until they are all out of memory. Believe me, the jobs are there....
Oct 09, 2008 | Xerox Phaser 6100/BD Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
PRINTING ERROR
> Home > Support & Drivers > Knowledge Base
Solution --> ERROR 0082" name="Note" /> Phaser 790 / DocuColor 2006 Printer's: Cancel print job and cycle the printer's power
  • On the printer's Control Panel, press the Cancel Key (12 KB).
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the CANCEL key.
  • If the error message persists, turn the printer off for at least 30 seconds and remove the computer interface to the printer (17 KB) before turning the printer back on.
  • Use the menu keys to perform a front panel reset (under RESETS menu).
  • If the printer redisplays the error message upon reboot, a file is likely STUCK at the front of the print queue. Use the front panel RESETS menu to CLEAR LOGS AND QUEUES, which will delete all print jobs in the printer's disk spool.
    Note: The READY message may only appear briefly. You may need to keep repeatedly pushing the MENU key to gain access to the front panel menu.
  • If the front panel menus can not be accessed turn the printer off for 30 seconds and then turn the printer back on.
  • If it is known which print job was last sent to the printer, try to reprint the last job spooled, which may be the cause of the error. Step 4 on clearing logs and queues may need to be repeated to eliminate the crashing job.
Note: Most XX82 or XX1E front panel error messages are NOT hardware related, but caused by a specific print job or application.
Mar 04, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox Phaser  8500/DN Printer Logo
1,248 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
