Question about True Fitness TRUE ES900 Treadmill
I have a stuck key error on my ES900 treadmill
Stuck key error on my treadmill
Sometime talcum powder under the thread will get it working again, but you may eventually need a new tread. Less likely, a problem with the motor especially if it's underpowered.
Jul 31, 2016 | Vision Fitness - T9800 HRT Full Commercial...
Stuck key
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 33 9 33i Treadmills Consumer SPORTSMITH net
Jul 15, 2014 | Precor 9.33 Treadmill
Precor gfx 9.33i displays "stuck key"
Corrective Action
Apr 20, 2014 | Precor Deck, Treadmill, OEM
How do I fix an E5 error message on an Ironman 2300.1 treadmill? What does this error message mean? How do I get a manual for this treadmill?
go to www.fitness.manualsonline.com or www.iconservice.com and download for free.
E5 means a key stuck ,some Upper PCA has been failled.
Try to RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jun 30, 2012 | Ironman Exercise & Fitness
Two lines appear on the console screen and incline starts going up, then when key is removed all lights go on but nothing works.
I assume you are talking about the safety key. It should have a string attached to it and a clip on the other end of the key's string.
The key is a safety feature and the key should be in the control panel and the clip attached to your shorts or shirt when you are using the treadmill. If you fall of the treadmill, the clip pulls the string and the key is pulled from the panel on the treadmill. This should stop the treadmill instantly by cutting main power to the unit. Main power is shut off because the key is a safety device and it MUST work every time. To help avoid design errors or unreliable stops when the key is pulled, a good designer will shut everything off, not just the motor for the tread belt. I would say your unit was designed by a good design team since everthing goes off when the key is pulled.
From my point of view, it is working as designed unless you are talking about a different key.
I know someone who did not wear their safety key and they slipped on the treadmill, the treadmill threw them into the wall behind the unit and they were stuck with their leg against the treadmill. The belt on the treadmill wore their skin down to the bone on their knee in only a few seconds. Lesson one, keep your treadmill at least 3 feet from the wall. Lesson 2, use the safety key and clip.
-Mark
Jul 17, 2011 | Reebok V 680 Treadmill
Stuck in safe mode
Error Code: Replace Safety Key (SAFE)
Meaning: Safety key is not recognize
Diagnostic: Replace safety key
If problem persist replace upper display board
you should also try cleaning the area where you insert the key magnetic
Sep 11, 2010 | Landice L 7 Club Cardio Trainer Treadmill
Key STuck Error
The key pad is not functioning properly thus this error is flashed you will need to replace key pad. Since I don't know where you are then the place to get the part is from precor directly the will ask Model & Serial #s
WORLD HEADQUARTERS20031 142nd Avenue NE
P.O. Box 7202
Woodinville, WA 98072-4002
T: 425-486-9292
T: 800-786-8404
www.precor.com
Jun 30, 2010 | Precor C954i Experience Treadmill
Stuck Key Error Message on Life Fitness F3
Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
May 03, 2010 | Life Fitness F3 Folding Treadmill with...
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Jul 28, 2009 | Life Fitness T3 Treadmill with Advanced...
True Fitness TRUE ES900 Treadmill Logo
Top True Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a True Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
