Question about Samsung SGH-T959V Galaxy S 4G Android Smartphone
Phone battery charging problems
My phone states that the battery is dangerously low and does not charge the battery when plugged in (it shows on the display that it is charging). It also gets very warm. I put in a battery that I knew had a charge and had the same symptoms. It also drained most of that battery in a few minutes. I know this because I have another of these phones to test the battery in and I am working with a brand new battery. At one point I also had an overheating warning icon come up on the display. I have replaced parts in laptops, so feel comfortable taking these types of devices apart. Are there any components that need to be replaced?
SOURCE: Samsung SYNC Charging issue;
Just had a rand new samsun u900 soul deliveredand this has the same problem. Has anyone found a fix for this?
Posted on Nov 13, 2008
  • 567 Answers
SOURCE: Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Posted on May 11, 2010
guru_fixya
  • 944 Answers
SOURCE: Charging paused. Battery temp. too high or too low
In my technical experience
this occurs mainly in the samsung mobile phone
it is not because of your battery.it is because one of your ic chip is being damaged......you need replace it.you can touch the phone internal chip and see which one of the chip is getting more heated up..you need to replace it..can you please tell me your model no.?so i may help you in chip replacement.
Posted on Jul 22, 2010
  • 8404 Answers
SOURCE: phone will not stay charged
Replace the battery.
Posted on Aug 09, 2012
SOURCE: how to fix charging port on a samsung galaxy s2
Hello sir!
Your phone Software is corrupted try to update the phones software with the new jelly bean, Then try these tip
Thank you
Regards
MK Sam
Posted on Aug 11, 2012
Samsung gt e3213k charging problem.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 07, 2012 | Samsung Cell Phones
Samsung SGH D807 Charging Problem and no screen display
Have you try to use another similar charger to charge your phone to see if it ill charge? because it could be that your charger is bad,. But if you have done that and it is same thing, it means the charging port of your phone is malfunctioning, that is why you have to use repetitive effort before it can charge.
Your battery is not charge due to the bad charging port of your phone, so your phone battery can not hold charge.
To resolve 1 and 2 problem of your phone, all you need to do is to change the charging port of your phone in other for your phone battery to charge and for your battery to charge.
Replace the charging port as said and you will see that your phone battery will charge.
For your screen, is it that the entire screen is black that you cannot see anything, not even text or see names from your contact? if it is, what you need to do is to change the flex on the the screen of your phone and you will see that your screen will display as you want it.
Take care.
May 04, 2010 | Samsung SGH-d807 Cellular Phone
Battery
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Jul 20, 2009 | Apple iPhone Smartphone
My iphone 3g won't charge more than 10%....
it has corrosion in the charging hole or insde where the battery charging slots are
Jul 12, 2009 | Apple iPhone Smartphone
Wont connect
replace battery
Mar 14, 2009 | Lands Phones
Battery meter shows low battery even when the phone is charged
A simple reboot of the phone can resolve this problem. Failing that a complete resync with iTunes does the trick too.
Feb 23, 2009 | Apple iPhone Smartphone
Charging Battery
did u try to charge it connected to your pc? maybe its the charger
Feb 04, 2008 | Motorola Mobility Moto Q
Samsung SGH-T959V Galaxy S 4G Android Smartphone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
