Question about Zoeller M53 Mighty Mate Iron Body, Poly Base Automatic Sump Pump 1/3 HP
Zoeller m53 stays on - Zoeller M53 Mighty Mate Iron Body, Poly Base Automatic Sump Pump 1/3 HP
3 Suggested Answers
  • 3 Answers
SOURCE: Zoeller M53, pump keeps pumping half the power
try backflushing with high pressure water(carwash) if that doesnt work you have to remove the bottom plate to expose the impeller and remove debri,gasket will probably have to be replaced(silicone) will do
Posted on Oct 31, 2009
john224
  • 1378 Answers
SOURCE: My Zoeller M53 Sump Pump
If your seal or gasket failed and water penetrated into the motor cabinet how certain are you that whatever you have done has actually remedied the underlying issue of the pump being grounded?
A new M53 is ~$125 - $150 and the oil is not something you can walk into the hardware store and pick up off the shelf. I'd want to be certain you have fixed the ground first. Having worked on these in the past it is unlikely you are going to fix anything wrong with the winding, especially for less than a new unit.
If all is OK and the oil is all you need ask around at local pump repair shops for 10 or 20 weight non-detergent pump oil...they should know what you want and if they sell it, you should be all set. As for the amount, pour it in slowly until you see the winding is fully submerged. You need to leave room at the top to allow for thermal expansion of the oil.
John
Posted on Aug 29, 2011
How much wattage is needed to run z57 zoeller pump
It probably draws about 6 amps so the power is 720 watts. Put it on a separate 15 Amp fused line so it doesn't put electrical noise into other items such a TV or radio for best results.
Apr 28, 2014 | Zoeller M53 Mighty Mate Iron Body, Poly...
Tip
Fixing a Zoeller M53 Sump Pump that won't turn on. Turns on by tapping or...
Just wanted to share my fix story. A couple of years ago I had a problem with my zoeller sump pump to turning on but it would if I ever so lightly tapped it or the discharge pipe. Naturally I suspected the switch and replaced it with the same results. I ended up zip tying a piece of foam to the float and bingo! This worked great for awhile until the foam loosened and got stuck. So back to the drawing board. I noticed on a parts list that zoeller recommends changing the float arm when replacing the switch. Put in a new float arm and it works great! No foam needed. I never thought to replace it in the first place because the old one moved fine but when compared to the new arm the new one is much smoother. I was able to remove the old arm with channel lock pliers and the new piece is press fit with some loctite #609 that came with it. Hope this helps!
on Apr 04, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
What is a check valve on sewer sub pump
Copy following link:
http://waterheatertimer.org/Repair-water-heater-valve.html#check
Add a comment and describe what you are connecting for more assistance.
Apr 29, 2013 | Zoeller M53 Mighty Mate Iron Body, Poly...
I had to reinstall float on my M53 but am not sure if the weight in the float needs to be on the bottom or top when installed
I'm not expert but have two M53 Zoeller sumps, one in the pit another as a spare which I plan on rebuilding. The weight on the float is at the bottom of both. Hope that helps.
Dec 17, 2012 | Zoeller M53 Mighty Mate Iron Body, Poly...
Fixed! Zoeller M53 won't turn on. Will turn on with a slight tap.
I had the same problem of pump not turning on unless I tapped the pipe to create a vibration. I took the float off and cleaned the grime / buildup. The buildup changed the buoyancy of the float (made it heavier) such that it did not float high enough to trigger the switch. Once cleaned, the float floats much higher above the water line and triggers the switch.
My Zoeller M53 Sump Pump Shorted out since the gasket seems to have partially rotted after 2 years Itis not used that often. I opened the wrong area of the pump and drained part of the oil. WHAT TYPe...
John
Aug 29, 2011 | Zoeller M53 Mighty Mate Iron Body, Poly...
I can here the pump humming, but it's not pumping
If your impeller is free and not clogged, check your check valve it may be stuck.
Jun 08, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Where can i buy a replace float road for a m98-b zoeller water pump
zoeller is a pump normally found only at plumbing and heating supply houses. they should carry or can order thge part for you
Jan 04, 2010 | Zoeller M53 Mighty Mate Iron Body, Poly...
Oct 31, 2009 | Zoeller M53 Mighty Mate Iron Body, Poly...
Zoeller M53 Mighty Mate Iron Body, Poly Base Automatic Sump Pump 1/3 HP Logo
44 people viewed this question
Top Zoeller Electrical Supplies Experts
Craig Butler
Craig Butler
Fred Sops
Are you a Zoeller Electrical Supply Expert? Answer questions, earn points and help others
