Question about Bulova Chronograph Watch
Cannot reset sweep hand to zero on my Bulova Marine Star
I cannot reset the sweep hand to zero. As I "play with" the 3 buttons, it keeps resetting at various points but I cannot discern the system.
  • 3 Answers
SOURCE: pressing reset doesn't go to zero
Pull out the crown and use either a combination or one of the cronograph buttons, this will allow you to adjust the hand positions
Posted on Dec 01, 2009
ONECCO
  • 3 Answers
SOURCE: Just had battery changed in my Tag chronograph.
I love these watches, don't you?
Posted on Aug 16, 2009
  • 2501 Answers
SOURCE: bulova marine star 96B01 japan movement
Go to "boluva.com", select your area.
Click on one of the pictures and enter your watch style in the search box (try 96D09).
When the details appear click on "instructions".
Posted on Feb 25, 2010
escapement
  • 2334 Answers
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
  • 17 Answers
SOURCE: I NEED MANUAL INSTRUCTION
You can find it here:
http://www.manualsonline.com/manuals/mfg/bulova/bulova_watch_product_list.html
or you can have a familiar manual from Citizen watches' website (technically almost the same. Citizen owns Bulova now)
Posted on Feb 17, 2011
How do i set both times i cant fugure out how to sync the digital to the clock
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps. Source: how to set time on a bulova marine star 96C30
This solution is from fixya member ropickym Fixya
Jul 03, 2014 | Bulova Marine Star 96C30 watch
How to set up second hand and chrono minutes for bulova 98B105 back to zero setting?
If you haven't got the user instructions you can get them via the following link:-http://www.bulova.com/watches/bulova/marine-star/98b105/
You should see "download user manual" at the bottom of the page.
Mar 31, 2011 | Bulova Marine Star Calendar #98B105 Watch...
Bulova Marine Star with chronograph. The minute hand of the chronograph resets to the 'one minute' location, not the top of the dial. I tried pulling the dial out and pushing the 'A' button and let the...
I have the exact same issue with the minute hand resting at the 1 minute mark and now I have condensation under the glass. The watch is only 2 months old so I think I will return it.
Nov 14, 2010 | Bulova Chronograph Marine Star #96B99...
Need operators manual for a bulova marine star 90A07
While I can find "Marine Star" in the list of models, I could not find one with the same refernce number.
There are a number of models so if you go to http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1 ", you may be able to find one that looks like yours.
If you click on a watch, details appear and these include operating instructions.
Apr 11, 2010 | Bulova Marine Star 96C30 watch
I need a manual to operate a bulova 98G70 marine star wrist watch
Copy "http://www.bulova.com/brands/bulova/bulova.aspx?brand=bulova#coll_id=30&coll_name=Marine%20Star&gender=1" into your search engine and you should arrive at the Boluva web site page listing Marine Star models.
I couldn't find your particular model but perhaps one of those listed is similar to yours.
Mar 19, 2010 | Bulova Marine Star 98G71 Wrist Watch
Pressing reset doesn't go to zero. sweep second hand goes to 57 seconds
Nov 20, 2009 | Baume Et Mercier Baume & Mercier Hampton...
How to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
hope this helps.
Feb 23, 2009 | Bulova Marine Star 96C30 watch
Re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. ashfaque.r@googlemail.com
May 18, 2008 | Seiko SNA553 Alarm Chronograph
SECTOR CHRONOGRAPH 200 WATCH
That's easy. You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Sep 19, 2007 | Watches
Bulova Chronograph Watch Logo
363 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
