Question about Garden
Qualcast suffolk punch keeps cutting out
Lawn more ran for a while,then started making like a revving sound and eventually cut out
4 Suggested Answers
paulrelliott
  • 69 Answers
SOURCE: I have a suffolk punch 14s the engine cuts out
try repacing the fuel filter it sound's like not enough petrol is gettng up to th rail for high rev's, could even be a weak pump but try the filter first & make sure the cover cap is sealed properly I use a bit of silicone or hermetite red as air can back into the system overnight if not sealed & you have to re-prime with the ignition key swithing on & off at sec intervals, actually try priming first with the ignotion key, turn till dash lights come on and hold for 4 sec's then turn off wait 4 sec's & repeat, you shoul hear the petrol pump buzzing each time, might just be air in the system or a leak & that will show it up!
Hope this helps !
Posted on Sep 23, 2009
  • 110 Answers
SOURCE: My mower is not cutting level. I have a new base
If the baseplate meets the cutting cylinder across the entire cutting width, it's adjusted properly.
Check that the front roller is level - it usually IS as simple as that.
If the roller has ben replaced with wheels, check that they are the same height.
Posted on Sep 24, 2009
mikehowy
  • 177 Answers
SOURCE: AM TRYING TO RESTORE A SUFFOLK PUNCH COLT LAWN
more info
Posted on Jun 07, 2010
Where can I get a Manual for my Suffolk Punch Petrol Mower 17SK
Hi anon the easiest place would be QUALCAST direct.
Aug 11, 2014 | Garden
SUFFOLK PUNCH PETROL MOWER 17SK
check and make sure all the tires have the same pressure
Suffolk punch manual
Ivan all fuel now is unleaded. It doesn't really matter only the fact that you may need two stroke oil in it as well as petrol.
May 26, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Can't remember how to keep my Qualcast Suffolk running!
There is a video on u tube and a wed site the old lawnmowers club .
Jan 10, 2018 | Garden
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Aug 22, 2009 | Garden
Webb Diplomat 350 Petrol Lawn Mower stops running 10 minutes
The 'DIPLOMAT' series of WEBBs is bad news, its NOT a WEBB! Webb were swallowed by qualcast-atco-suffolk, who dunped Webbs tooling, & dressed up punches & commodores in thin disguises, dumped the briggs & stratten engine for their own alloy job, & charged a rip off premium for the Webb decals!
The qualcast suffolk alloy engine suffers from a WIPAC electronic ignition unit. As it gets old, it fails, sometimes completely, sometimes as it warms up. Once cool, it works for a while again.
Not too hard to replace, but hard on the wallet, £69 genuine, £40 fake! On the whole its not too bad an engine if cared for & oil changed often. better to look on ebay for a cheap used HONDA engine & transplant! R-E-L-I-A-B-L-E !............I did! ( £35 honda gc series, 5,5hp! )
Jul 27, 2009 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
