Question about Sony VAIO VGN-S580P Notebook
Upgrade Sony VGN-S580 to 2GB memory
I have installed the first 1GB in the bottom of the laptop. I need assistance in the installation of the second 1 GB.
I believe it is under the keyboard but not for sure. How and where is the second location?
I have two 1GB DDR2 PC2 4200/533MHz Notebook cards.
Thanks, I need your help before I break something. I had taken out all the screws on the bottom of the laptop but it did not come apart easily.
  • w_woofter Mar 12, 2009
    Thank you very much for the info.
    The document was what I needed. It took me about 15 minutes to install and test/valid.
    You were a great help and I am happy I found you.
    Bill
  • 370 Answers
If you go to this link, then go to page 100, it will give you step by step directions on upgrading the memory that is located under the keyboard.
http://www.docs.sony.com/release/VGNS500_USA_userguide272.pdf
I hope this helps you out.
Posted on Mar 12, 2009
  • 4 Answers
Flip the notebook upside down and disconnect the power adoptor and remove the battery from the notebook and you will have a flap showing a rectangle shape open that flap and hold the memory in45deg in the slot and press the memory in and it will get lock in the slot
How to install ram memory
General two options:
1. Look at bottom of laptop and notice the memory icon. You will need to unscrew the panel to upgrade memory.
2. Memory is under keyboard in which you will have to remove keyboard to upgrade memory.
May 09, 2012 | HP Acer Aspire As7750g-6645 I5-2450m 1gb...
Sony vaio vgn fs515h I want to upgrade the memory on my laptop to 2 x 1gb cards - are there any instructions/processes to follow?
You need to buy the same kind of memory and make sure your laptop support that amount of memory and any BIOS settings are updated for it.
Dec 29, 2010 | Sony VAIO VGN-FS515H Notebook
I have a vgn-b3vp (pcg-5b1m) sony laptop, can i upgrade the memory if it has 512 of none-removable memory and only 1 bank.
Yes, you can use the 1 bank and get higher graded memory, another 512 in the 1 bank would make 1gig, you can probable get as much as 2 gig in the bank to make a total of 2.5 gigs by buying a 2 gig memory stick.
Jan 27, 2010 | Sony VAIO VGN-B3VP Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Need disassembly instructions to install additional RAM
If the ram is upgradeable, there should be an access port on the bottom that can easily be removed. Open all access ports until you find the one for ram. Then you should be able to upgrade the ram.
May 31, 2009 | Sony VAIO VGN-NR110E/W Notebook
Can Sony VGN use single memory module?
You're gonna need two 1gb modules.
Hope this helps.
Best of luck!
Feb 28, 2009 | Sony VAIO VGN-N250E/B Notebook
Vgn a170b ram upgrade problem
your ram IC not compatibel or not work well with your laptop
it's recentlly happen
please rate
Jan 21, 2009 | Sony VAIO VGN-A170B PC Notebook
MEMORY UPGRADE
from the white page I found:
"The 17-inch widescreen Sony Vaio VGN-AR230G, the first entertainment Sony’s AR notebook with Core 2 Duo Mobile (Merom) processor, is now available at SonyStyle.com. The Vaio VGN-AR230G comes with a T5600 (1.83GHz, 2MB L2 cache) CPU, an 1GB DDR2 SDRAM (expandable to maximal 2GB), an 200GB 4200rpm SATA hard drive and a dual layer DVD burner ."
There u are, only 2GB.
/Teis
Dec 29, 2008 | Sony VAIO VGN-AR230G Notebook
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Sep 21, 2007 | Sony VAIO VGN-S460 Notebook
Sony VAIO VGN-S580P Notebook Logo
290 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
