Question about Timex (T439S) Clock Radio
Setting time whenever i try to set the time i am only able to set the minutes. how do i set the hour?
  • Anonymous Nov 11, 2008
    i cant set the time or anything on it
I could not get this manual to load from the link. Other manuals would load, but not this one. I also found from Timex's website that Model T435 is almost identical to T439 except for the docking bay for IPod. Setting instructions and button configuration seems to be the same. Go here: http://www.timexaudio.com/pdf/T435_IB_92240907_93.pdf
Posted on Sep 08, 2008
Simply hold down the button you're using for minutes. After changing over a certain number of minutes, it will speed up and cycle through the entire range, so hours will start flipping by as well.
Posted on Apr 06, 2008
You can download a manual for the Timex T439S (MP3/CD Dual Alarm Color Change Clock Radio) here: http://www.timexaudio.com/support.asp?Productid=10028 Just choose the T439 model from the drop-down box and it will bring up a 10-page Adobe PDF manual.
Posted on Sep 07, 2007
How to set the time
press and hold clock set, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Or
press and release clock set, hours and minutes will flash, press hours button to correct hour and then minutes button to correct time. Then release the hours set button.
Instructions are sometimes specific to make and model.
Jul 08, 2016 | Audio Players & Recorders
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 | Home
Sangean h2o1 clock is flashing. The radio display doesn't flash - only the clock. I've reset the clock, changed the batteries, and generally played with the other settings. Can't figure out why the time...
Here's the thing: When you change the batteries, the radio thinks you need to reset the time, even though the time has been preserved and is correct even after you change the batteries. Here's what you do: Pretend you need to reset the time. With the radio off (recommended), press and hold the "Band" button with the "set" notation underneath it. The hour will flash. "Reset" the hour by using the tuning buttons, as you would if the radio were new, and then change it back to the correct hour. Press the "Band" button again and repeat the process for the flashing minute display. Press "Band" again to end the process. You will have successfully fooled the H201 into thinking that you have reset the time, and the time display will have stopped flashing. (This does not appear to work if you do not actually pretend to change the hour and minute and just keep pressing the "Band" button -- you have to go through the procedure as though you were actually changing the time.)
Aug 31, 2010 | Sangean H201 AM/FM Radio
Cant set it
    Setting the Time
  1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
    Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
    Once the time is set, press the upper left button to save the setting.
  2. Backlight
  3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
    The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
    Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
  4. Setting the Alarm
  5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
    Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
    When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
I cant figure out how to work it my casio gshock
    Setting the Time
  2. Backlight
Aug 14, 2010 | Casio Watches
How do I set the clock on a room tech beingz
There is a switch on the back to set time, alarm, or display time. Select the switch to time set first. Tap top of unit to toggle between settings blinking display is the one to be set. Change it bi tapping on the sides ( ) or(-) don't forget the 12 hour display or military 24hour. Switch back to clock display when hour and minute display are both blinking or the setting will not take effect
Jan 26, 2010 | Hasbro Room Tech Beingz Alarm Clock Radio...
I can change everything but the date. How can I change just the date on my watch. The model I have has 4 buttons (Mode, St/Stop, Set, and Light). Can someone tell me how to change nothing but the date?...
Hi 1234910,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Jul 16, 2009 | Timex 1440 Nylon watch
I need the instructions for alarm clock model number cc208s
Please try this....
Setting the Clock
1. Press and hold the Clk Set Button.
2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
3. Release the Clk Set Button to set the time.
Setting the Alarm
1. Press and hold the Alm Set Button.
2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
3. Release the Alm Set Button to set the time.
4. Adjust the Auto/Off/On Button to Auto.
5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
Cheers!
Jul 13, 2009 | Audio Players & Recorders
I have a Zenith ZG120M alarm clock radio. I can't set it.
Here is how I set my ZENITH ZG120M radio alarm clock.
1) PRESS AND HOLD DOWN the HOUR BUTTON and then PRESS the TIME BUTTON to set the correct hour.
2) PRESS AND HOLD DOWN the MINUTE BUTTON and then PRESS the TIME BUTTON to set the correct minute.
To Set The Wake Up Time
1) PRESS and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the HOUR BUTTON to set the desired hour.
2) Press and HOLD DOWN the SNOOZE/ALARM SET BUTTON and then PRESS the MINUTE BUTTON to set the desired minute.
There are two light indicators that light up on the left side of the LED display...the top light indicator will come
on once the time turns to PM. The bottom light indicates the alarm is set.
Mar 25, 2009 | Timex T309TT Clock Radio
Clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
Aug 19, 2008 | Alpine IVA-W200 2-DIN DVD/CD/MP3/WMA...
Timex (T439S) Clock Radio Logo
714 people viewed this question
Top Timex Audio Players & Recorders Experts
Greg Cann
Greg Cann
Gyula Lacz
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
