Question about Electrolux Menalux Mpk1 Numatic Sales Kit. Replacement Consumables For Henry, Hetty. Includes 1 Pack Dustbags, Micro Filter, Motor Filter, Mini Turbo Nozzle And Pack Of Lemon Air Scent Sticks
How to replace a hetty front wheel
Front wheel replacement
Static electric shocks
This occurs when the air is dry. The vacuum builds up a static charge when running. If you touch something metallic, you will get shocked. To dissipate the charge on your body, run your hand along a wall - it helps to reduce the shocks.
Apr 29, 2015 | Numatics Numatic Hetty 200a Hetty Hepa...
My Hetty Hoover has no suction, but when I take the filter out it has suction Please help!
Throw away your old filter if it is not cleanable. Only clean it if it is a washable filter. If not, buy a new one
Dec 10, 2014 | Hoover Vacuums
Put my hetti hoover back together
I think someone needs to go back to first grade and learn how to form a question.
Aug 18, 2014 | Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Hetty not suckin up no suction wot can I do
take it apart...something stuck in hoses
Oct 02, 2013 | Vacuums
What size fuse do i need for a hetty vacum cleaner
Replace according to the same type seen on the unit, the amps are important as much as the type of fuse used.
Aug 02, 2013 | Numatics Numatic Henry / Hetty Vacuum...
I have a hetty hoover my wife sucked up water by mistake she cleaned it but it is so loud what could the problem be
Liquid plus motor usually results in a burnt out or ruined motor. Replacement is needed.
Jan 29, 2011 | Vacuums
Hetty hoover not working. It was working ok until I opened it up to search the bag for a missing jigsaw piece and I put it all back and I hoovered the mess on the floor, then switched off and switched on...
Know cut off switch, its just not getting power ? 2 things its ether at the wall plug or in side the unit. I have never found a fuse in side them , so it may be just a lose wire did you try other plugs in the house . good luck DFD
Jan 22, 2009 | Henry Numatic "" Canister Vacuum
Electrolux Menalux Mpk1 Numatic Sales Kit. Replacement Consumables For Henry, Hetty. Includes 1 Pack Dustbags, Micro Filter, Motor Filter, Mini Turbo Nozzle And Pack Of Lemon Air Scent Sticks Logo
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
