Question about Hoover Washing Machines
Ho4 hoover washing machine give h04 fault
SOURCE: Hoover washer model VHD9143ZD
Have the same problem. Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF position. Select again the programme and press the START/PAUSE button to switch the machine back on.
We recall having this problem with a previous Hoover washing machine and it was solved by cleaning the filter. The service manual recommends you clean the filter once a month. The procedure is as follows:
1) Open the flap
2) Only available on certain models: Pullout the corrugated hose, remove the stopper and drain the water into a container.
3) Before removing the filter, place absorbent towel below the filter cap to collect the small amount of water likely to be inside the pump.
4) Turn the filter anti-clockwise until it stops in the vertical position. Remove and clean.
5) After cleaning, replace the filter and lock by tightening the filter screw. Then follow all procedures described above in reverse order.
Hope that helps :)
Posted on Mar 15, 2008
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
SOURCE: Hoover Vision 1600 drum not spinning?
I have similar problem with same model unit, found brushes on motor worn to point copper contact is hitting and scoreing commutator. Easy checked, ensure power completely disconnected, lie machine on side and gently rotate drum looking in side the motor. The commutator is what looks like a circular block of copper segments which will rotate with the drum and should be evenly worn and coated with carbon from the brushes. If you see a clean copper area, usually in the center, then the brushes are worn down below workable levels. Suggest replacing should resolve problem.
Posted on Jun 08, 2008
  • 12 Answers
SOURCE: Need User Guide for Hoover washing machine
you can download manual from hoover.co.uk
Posted on Mar 27, 2009
  • 155 Answers
SOURCE: My hoover washer dryer VHD is showing a fault E11
It means there is a problem with the dryer board on it.You can try removing
the lid and just check the dryer control board on it.Make sure the
connections are ok and that none of the wires are broken.Then if the wires are ok the dryer control board will need to be replaced.
Posted on Apr 10, 2010
My Hoover greenway washing machine is showing ho4 and message icon. What does this mean
If the following error codes are displayed, switch OFF the machine and contact Hoover Service: 0, 1, 4, 5, 7 and 8.
Feb 02, 2016 | Hoover Washing Machines
Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
Canon DLC: Article: Canon EOS Error Messages: An ...
www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
problems installing digital solution disk - Canon Community
community.usa.canon.com/t5/PowerShot/problems-installing.../225
How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
Lost user manual for my washing machine
Try this, in your browser bar, type in: HOOVER AFTER SALES SERVICE.
This should help you.
Please rate my solution.
Thanks.
Aug 30, 2009 | Hoover Washing Machines
Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Jul 27, 2009 | Washing Machines
AAA160 Washing Machine
yes most certainly, with leaks it is either the seals or cracks in hoses or rust holes in wash cylinder, but most likely the first too because of being a fairly new model
Jul 01, 2009 | Hoover AAA160 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Johnny Ramirez
Johnny Ramirez
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
