Question about Maytag Neptune MAH5500B Front Load Washer
Water will not drain on neptune MAH3000AWW washer tried different cycles. It started working for a while after we took back off and took things apart but now it won't drain at all.
  • 1 more comment
  • Raul Davila Mar 14, 2009
    fills with water but will not start washing, cycle ends and water is still in tub.
  • Anonymous Mar 23, 2009
    same exact problem- can someone address how to fix this issue on a clothes washing machine- the advice given seems to refer to a dishwasher
  • Anonymous Mar 29, 2009
    My front loader has the same issue and I tried all the cycles. Help:(
YOU HAVE TO HAVE THE WAX MOTOR REPAIRED, IT COST US 300.00, CALL THE MAYTAG REPAIR MAN. WE HAD IT FIXED AND IT HAPPENED AGAIN, WE ARE NOW SHOPPING FOR A NEW WASHER.
Posted on Mar 26, 2009
  • 221 Answers
There are many things could make a dishwasher not drain, here's a list of the most common reasons.
  • a clog or air gap in the drain line, often the problem is where the drain line attaches to the household drain line, if you remove this line you can clear any debris from the hose or hose connection.
  • a defective pump, your dishwasher pump ejects the water.
  • many dishwashers use a drain valve or solenoid, the solenoid can sometimes become stuck or defective solenoid.
  • a defective motor, if the motor is'nt turinig or working the dishwasher won't drain.
Posted on Mar 13, 2009
MAH3000AWW Does not spin fast enough on spin cycle Clothes are still full of water when done.
hi there ..sounds like your appliance is not spinning at all........(a) check if your drain pump is working correctly..(simply fill water and turn to drain)..(b) possiblity that the clutch drive mechanism is badly worn and needs replaced
regards Sir Galahad
Aug 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAH3000AWW Trips 20Amp Breaker at rinse cycle
The motor is known to have bad windings. Do a search for "Neptune Washer will not start" Also just inside the control panel where the start/stop sw is should be a paper folded with the diagnostics test and schematic. It is tucked under the pressure sw attached to the back. If not there then search "Maytag Neptune motor phase test" There is also a Service Manual FREE at Goetlieh's site.
Sep 27, 2008 | Maytag Neptune Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
Maytag Neptune MAH5500B Front Load Washer Logo
595 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
