Acer audio jack retask - Computers & Internet
How do I transfer tapes to cds on acer 5315
I would purchase a USB audio to USB convertor. You will then be able to copy all audio.
Feb 25, 2015 | Acer Aspire Computers & Internet
How do you hook up sound from surface rt to acer monitor 2014
To connect anything to the speakers on your acer monitor you need to use an audio patch cable that has 1/8 inch or mini headphone jacks on each end. Like this one.
5mm Male to Male Stereo Audio Cable...
You connect one end to the headphone jack on your Surface RT and the other to the audio in jack on the monitor. Make sure the power is on for the monitor and that the volume on both is a third or half way up and you should be able to hear the sound.
This is for the monitors user manual.
Acer AL1715 User Manual Amazon com C2G Cables to Go 27413 3
Jun 13, 2014 | Acer 22" X223w LCD Monitor
4738z acer diagram
This sounds as though the audio jack has become worn. It is possible that you could close the contacts up (on the audio jack) again, if this isn't possible you will need a new audio jack fitting at your local computer shop!
Oct 02, 2013 | Computers & Internet
What cord do I need to connect my acer notebook to the t.v for netflix
this is pretty easy. Since you're acer aspire doesn't have an HDMI out port, then you're gonna need a VGA cable to connect your acer's video signal to the TV.
This cable should do: http://www.amazon.com/10ft-Resolution-mo...
Now, since it's not HDMI, you won't get audio coming out the TV, only your laptop. But if you want audio out your tv, all you'll need is audio cable, which you can connect to the headphone jack (audio out) and then into the AUDIO IN jack on your tv.
the audio cable: http://www.amazon.com/Cables-Unlimited-A...
After this, just hook it up while your tv is turned on, switch to the VGA channel on your tv, and a window should come up on your tv asking you to configure the settings. For audio go to the control panel while the audio cable is hooked up, go to sound settings, and switch the default audio to speakers, or headphones, im not so sure what it is on a netbook
Aug 16, 2011 | Acer Computers & Internet
Hey, I got a little problem here...I am using sony vaio vpcee23fx . The problem is there is a sound like buzzzing coming out from the multumedia speaker when I plug the jack in to my sony audio jack. While...
Probably, the multimedia audio jack cable has kinked and in turn gone partially bad; especially close to the audio jack head.
What you can do is take it to an electronics/phone/tablet repair shop and get the jack head replaced.
Should work fine after this.
Oct 11, 2017 | Sony VAIO VPCEE23FX/BI Notebook PC
Hello. Has Intel d946gzis internal connector SPDIF to add a cable with coaxial or optical exit? Thank you.
No, according to intel, it only has: • Front panel audio connector, including functionality for: ? Line out ? Microphone in Desktop Board Features • Back panel audio connectors that are configurable through the audio device drivers: ? Line in/retasking jack ? Line out/retasking jack ? Mic in/retasking jack Audio drivers and utilities http://support.intel.com/support/motherboards/desktop/
Jul 03, 2011 | Intel D946GZIS Motherboard
How do I get sound from the Acer LCD monitor?
connect stereo audio cable from monitor to pc audio output
Mar 27, 2010 | Acer 22" X223w LCD Monitor
Hi, I'm trying to connect my ACER 5738 notebook to my Sony Bravia KDL-W4500 via the HDMI connections. I can get video fine, but no sound, it still comes out of the notebook speakers. Any ideas?
Buy an audio cable: stereo jack male at one side and RCA Audio on the other end. Connect the male jack to the laptop's headphones and the RCA channels to the audio inputs at the back (you will see the two channels - white and red colored ones).
Feb 21, 2010 | Acer Computers & Internet
Where is audio input audio input jack for recording music on acer 4620
in most acer extensa series these jacks must be in the front bottom.
Dec 16, 2009 | Acer Extensa 4620 Notebook
I have 3 ports on the front of my acer aspire 5100 i mo 1 is mic and 1 is headfone wot does the other 1 do??? plz heeelp
Standard audio configuration for computers is:
Pink jack is a Line In for microphones, green jack is a line out for headphones, and the blue jack is a digital line out to connect compliant stereo systems.
Dec 30, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
